Half a crank and then kit-kit-kit-kit-kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2007, 08:51 AM   #1 (permalink)
View jpbear's Photo Gallery
4th Generation Half a crank and then kit-kit-kit-kit-kit
My 98 Camry yesterday refused to start.
I had driven it for about 8 miles and stopped at a place to pick up something. After about 15 minutes are so, I tried to start it, the engine perhaps cranked once and then this noise started up under the hood that went kit-kit-kit-kit-kit-kit-kit-kit-kit-kit and the cranking stopped.
I looked under the hood and the nose was coming from the metal enclosure next to the engine - that houses one of the motors or something.
I had to call AAA and it was towed to a dealership. While I await the diagnosis, what could have been the problem with it? and how much would i have to shell out at the dealer..
jpbear is offline   Reply With Quote
Old 03-01-2007, 09:08 AM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Sounds like a weak battery to me. OEM car batteries have an average life span of 5 years or so. The other possibility is you have a charging system problem. The noise your describing is typically what happens when there isnt enough power in the battery to fully engage the starter motor. As usual everything at the dealer is going to cost a little more due to the higher labor rate.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-01-2007, 09:12 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
wait a sec... the AAA couldnt get you home?
terrastrife is offline   Reply With Quote
Old 03-01-2007, 09:22 AM   #4 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i second the batt...
i just had my batt replace and had similar probs...
Old 03-01-2007, 09:25 AM   #5 (permalink)
View kamrhee's Photo Gallery
While you're at it (changing the battery), get some info if your alternator is charging the system. These services are usually free from the place you purchase your battery.
kamrhee
1998 Camry LE 5s-fe (Stock)
2002 Toyota Highlander 1mz-fe (Stock)
My other car is a Bianchi
kamrhee is offline   Reply With Quote
Old 03-01-2007, 09:39 AM   #6 (permalink)
John
View MemphisR's Photo Gallery
well if by metal enclosure next to the engine he means transmission that might be why he couldn't just get a jump from the AAA tow truck but its near impossible to diagnosis a problem without seeing or hearing the vehicle, but a 98 would defintely have needed a trans flush by now especially the way camry trannys are ALWAYS dirty . . . that could be the start of your current situation
2000 Toyota Camry I4 2.2L (Super White II) - Garage Monster!
2002 Chevrolet Silverado V8 5.3L (Pewter) - Daily Driver
MemphisR is offline   Reply With Quote
Old 03-01-2007, 10:04 AM   #7 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
lol wow that could have been fixed by a simple jump, unless they tried it already and that didnt work.
that clicking is the starter not getting enough power to send to the distributor caps to get the spark plugs started for ignition.
man i hope you dont get raped at the dealership for this.
battery's need to be replaced every 6 years in the USA (if you get a standard type battery).
The problem you have is simply the chemicals in the battery not holding a charge anymore. I've helped 3 people with old battery's (gen 4 cam) start up with a jump that have your same symptoms. I've also had to jump my own car when i had left the radio on for too long while working on my car.
nodrogkam is offline   Reply With Quote
Old 03-01-2007, 12:58 PM   #8 (permalink)
View bill buttermore's Photo Gallery
If the dealership is honest and competent, they will test both the battery and the starter to determine whether they need to be replaced, they will also test the alternator to make sure it is functioning properly, and they should also check the cables and electrical connections to make sure they are clean and tight. At a dealer, I would guess this might cost $150 in labor charges plus the parts and labor cost of any components that need to be replaced.
bill buttermore is offline   Reply With Quote
Old 03-01-2007, 01:26 PM   #9 (permalink)
The tow guy did try a Jump but it didnt work.
The dealer did call and say he was going to put a new battery and test it. everything seems to be allright - (now thats a honest dealer!)
Old 03-02-2007, 08:38 AM   #10 (permalink)
Got my car back - with a new battery and it works like a charm. The dealer charged me 136$ including Labor (Carousel Toyota, Glen Mills, PA).
Thanks all.
Old 03-02-2007, 09:04 AM   #11 (permalink)
nodrogkam's Avatar
wow a jump should have worked like a charm if he knew what he was doing.
Anyways 136 isnt too bad, but i get the feeling the tow guy felt like towing a car.
Old 03-02-2007, 11:51 AM   #12 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
agreed. most tow guys prefer to tow because they get extra $$$, especially from AAA.
