Check Engine Light - P0172 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2007, 03:55 PM   #1 (permalink)
View RedCamry99's Photo Gallery
Hi Guys
I recently bought a second hand Toyota Camry ( 99, LE, 2.2L 4 Cyl) with 98K miles on it.
I got the check engine light a week ago after i put fuel that day. I just tightened the fuel cap and it went off for a while. But then it came again the next day. When i checked the code, it read P0712 - System Too Rich on Bank 1.
I drove with the light on and i started facing problems like engine started stuttering when standing in signals. Also one time i smelled foul odour when i stopped for the signal.
After few mechanics looked at the vacuum lines and air filter, i took it to the dealer for a full check up. Dealership says that the vacuum is leaking in the cruise control cylinder ( is there anything like that?? ) which is causing the check engine light to come on.
They are quoting around $335 to replace this thing.
I said i do'nt want the cruise control. Just fix the leak. But they say that its not possible to fix the leak without replacing the Cruise Control Cylinders.
Is this analysis correct ? I am not sure if they are taking me for a ride!!!
NOTE:
This is my first car and i do'nt know much about cars...
Thanks
RedCamry99
RedCamry99 is offline   Reply With Quote
Old 03-02-2007, 01:16 AM   #2 (permalink)
View toyomoho's Photo Gallery
The earlier model had an electric cruise system with metal cables running to the throttle pulley. No vacuum lines. Not sure on the model. Use a small bottle of natural gas, propane, etc with bottle on and flame out. Run over the areas of suspected leaks and see if the idle picks up. Then see if you can cap off any hose running to the leaking item.
Old 03-06-2007, 12:11 PM   #3 (permalink)
Surprisingly, the problem is not seen after i changed the fuel cap. I also do not see any problem with the idling when stopping for signals.
I do not know what really these dealer guys analysed.
RedCamry99
Old 03-06-2007, 01:03 PM   #4 (permalink)
93 Camry LE V6
Barcs's Avatar
View Barcs's Photo Gallery
If I've learned anything over the years it's not to trust dealers.
Barcs
Barcs is offline   Reply With Quote
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 01:52 AM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 10:00 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
