i would say if you really want to do this, just GET THE LIGHTS, then look at them and see what else you will need to do it, you will most likely just get by with making some custom brackets and doing some good bondo/fiberglass work. If you want to get the s15 grille as well, then you are looking at a lot more issues. You then have to deal with the length of the grille and the way that relates the the positioning of the headlights and how everything will be too wide or not wide enough for the camry body. I support you. I am going to do almost the same thing in a couple years with lexus es300 projectors, to keep the toyota feeling
... anyways, did yousee that integra in one of those import magazines withthe s15 headlights, and some honda parts, some bwm parts, etc...? is that what prompted your desire to try this?
