93 camry crank but no start. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2007, 10:14 AM   #1 (permalink)
View SammyJ's Photo Gallery
3rd Generation 93 camry crank but no start.
Where is the fuel pump and filter located
Help please....
Here is my car info............
1993, TOYOTA CAMRY V6 (3VZ-FE) XLE Auto Black 190K
SammyJ is offline   Reply With Quote
Old 03-02-2007, 11:42 AM   #2 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Help please....
Fuel pump should be located under the rear seat bolted into the fuel tank. As for the filter, I'm not sure on a v6, but on a 4 cylinder is bolted to the driver's side framerail. It looks like a little tube canister with a line up top and a line on the bottom. Hope that helps.
edit... Have you checked to make sure the pump is working, before you go through all the trouble is sounds like you might be starting into? I mean, have you checked the fuses/relays, have you just turned the key on and just listened for the pump to work. You should be able to hear a humming sound if it was working. Then you could know a little better where to start. Also, I'd suggest downloading the gen 3 shop manual, I think there's a link to it at the top of the General Camry Discussion forum.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
Camry 2007 2.4L w/Manual transmission : Tough to start vinniemak 5th & 6th Generation (2002-2006 & 2007-2011) 4 07-07-2006 07:22 PM
93 camry no start xwrench2003 3rd & 4th Generation (1992–1996 & 1997–2001) 3 03-06-2005 05:19 PM
Stuffs for my 93 Camry toyotapro 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-10-2002 10:46 AM
