oil leak - valve cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2007, 03:15 PM   #1 (permalink)
View jeffbreeden's Photo Gallery
4th Generation oil leak - valve cover
I recently replaced my valve cover gasket which was leaking on a 97 4 cylinder.
The leak has returned ( or it was never fully sealed). I am seeing a oily area on the side of valve adjacent to the coil packs and also on top of the thermostat housing. Does anyone have any additional tips on the best way to seal up this area? I am going to try another gasket but I suspect I need to add some additional liquid gasket in this area to fully seal it up.
Any tips would be appreciated.
jeffbreeden is offline   Reply With Quote
Old 03-04-2007, 07:56 PM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
you will need from RTV to help seal the 'problem' areas - use it at any point where the mating surface isnt perfectly straight or flat. do make sure you torque the nuts on the plug tubes to the proper torque amount.
Old 08-08-2007, 06:25 PM   #3 (permalink)
View bcsbadboys's Photo Gallery
4th Generation
I'm having the same problem as well. I put a new gasket on, but I don't think I cleaned the mating surfaces enough. And I didn't apply any RTV silicone to the trouble spots listed in the Haynes. The guys at Car Quest said I wouldn't need to with a rubber gasket. I guess they were wrong.
1997 Camry LE 2.2L, 5SFE
160,000
bcsbadboys is offline   Reply With Quote
Old 08-08-2007, 06:46 PM   #4 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
i just replaced mine after a huge problem ... it should be cut and dry
remove the valve cover, put the new gasket in - clean the surface that the gasket will touch .... place the cover [with the gasket already in] back on .... torque the big spark plug nuts down enough and VOILA!
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 08-08-2007, 07:06 PM   #5 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
It shoudn't be that hard, just thoroughly clean the mating surfaces so they can have a proper seal
MIC0417 is offline   Reply With Quote
Old 08-09-2007, 07:09 AM   #6 (permalink)
ghettosled's Avatar
it wouldnt hurt to add some rtv to the problem areas. use brake cleaner to throughly clean the mating surfaces. then use some rtv where the gasket turns 90 degrees by the cam shaft and distributor. make sure the half moon plug is firmly in place and use some rtv there where the valve cover gasket mates.
Old 08-09-2007, 10:26 AM   #7 (permalink)
4th Generation
I have to go back and clean the mating surfaces again because of a small leak. Do I also need to clean the gasket of oil residue before putting that back on? If so, is brake cleaner safe to use with a rag to wipe off the gasket?
160,000
Valve Cover Leak mchodan 3rd & 4th Generation (1992–1996 & 1997–2001) 9 09-05-2006 10:40 PM
Oil Leak in 93 Camry LE 3VZ-FE V6 Front Valve Cover or Oil Pressure Switch? Xander 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-09-2005 05:27 PM
valve cover and oil pan 91RED3S MR2 Forum 4 04-10-2005 03:47 PM
Valve Cover Estimate ArmyofOne Camry & Solara Lounge 5 10-02-2004 10:15 PM
Aggonizing oil leak! IMPORTMyth01 MR2 Forum 1 08-26-2004 11:29 PM
