1994 V6 XLE (1MZ) Idler Pulley Noise, AFTER Replaced
Alright, I've got the 1MZ-FE in my camry. After about 6 months of squealing and squeaking, I bought the >$70 upper idler pulley (It's the one that's held in by a 14mm bolt and sits between the Cam gears (a bit lower actually) behind the upper timing cover.
So, I pull off the dogbone, I pull off the aluminum dogbone tower, and pull the timing cover. I pulled out the old pulley, and sure enough, you could shake it an it would rattle. Definitely not the sign of a good bearing.
I replace the bearing and bolt with the new one, and away we go.
Now, a day after the install, I start hearing more funny noises. I pop the hood and hit the new pulley with a shot of spray lithium grease and sure enough, it shuts up. I haven't pulled it off yet, and I'm relatively nervous to. Any particular reason this bearing could be making horrid noises a day after install, other than just a bad bearing?
Thanks for any input!
-James
