98 camry transmission leak help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2007, 02:33 AM   #1 (permalink)
View fordmandan's Photo Gallery
hi, my girl friend has a 98 camry with 4cyl automatic trans. the transmission is leaking out the bottom of the bell housing. i beleive is the torque converter seal or front pump seal? has anyone had this problem? does anyone know what else could possibly be? does anyone know how long it takes to remove transmission and any tricks to make it easier? any special tools needed to do this? i am going to fix this next week so any help would be great. thanks in advance..dan
fordmandan is offline   Reply With Quote
Old 03-06-2007, 09:20 AM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
need more info
have you been under the car?
if i were you i would clean up under there to find and isolate the problem
i would think the oil pan gasket (the main and most common leak problem)
Old 03-06-2007, 05:38 PM   #3 (permalink)
transmission leak
hi thanks for the reply. however i have been under car and cleaned and check for where it is coming from . is coming from bottom of bell housing and is transmission fluid. if you drive the car 100 miles you have to add a quart of trans fluid even worse in town with lots of stops and starts.drips real good. i am pretty confident it is the front seal or torque converter seal but thought someone who works on toyotas would have a better idea than me. i want to find out if there is any tricks to make job faster or easier. also is there any special tools needed to replace these seals. thanks,dan
Old 03-06-2007, 05:59 PM   #4 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
I think I have a similar problem with mine. Not quite as severe, though. I am pretty sure it would involve removing the transmission, and in my experiences, it's just as easy to pull the engine out at the same time. If someone could verify that for me, I'd really appreciate it. As for replacing the shaft seal, I would think it can be popped out with a slide hammer and then rig up a pipe the same diameter of the seal to drive it back in.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 03-07-2007, 03:22 AM   #5 (permalink)
thanks. i plan on dropping out the trans next week. i will see how it goes. hoping for some first hand hints on making it easier. does anyone know if front pump requires a special puller to remove? just trying to have all my bases covered before i get to that point. thanks in adavance...dan
Old 03-07-2007, 09:39 AM   #6 (permalink)
97 Avalon Silver Spruce
View parimento1's Photo Gallery
First check the seals around the axle where it attaches to the transmission. This is where mine was leaking from. could save u a lot of hassle.
parimento1 is offline   Reply With Quote
Old 03-08-2007, 03:52 AM   #7 (permalink)
hi, thanks for the reply but is no leakage around axle seals. only from bottom of bellhousing. thanks,dan
Old 03-14-2007, 04:12 AM   #8 (permalink)
The only okie in here
View OSUpeterson09's Photo Gallery
I dont know if you fixed it or not yet, but Im having the same problem but not a severe. Im replacing the transmission pan gasket and bolt. I know this happened on my buddys camry also, we drive 99 toyota camry I4's. You might check this. If you take ur car in for like an oil change, they should notice it and tell you exactly what it is at a toyota dealer
'99 Camry I4 - INJEN SRI - Clear Corners - Euro tails - New Muffler - Gauge color mod - More coming soon!
I'm looking for any oklahoma ppl with camrys on here. Let me know.
OSUpeterson09 is offline   Reply With Quote
Old 04-21-2007, 11:44 PM   #9 (permalink)
View apudapus's Photo Gallery
i'm in the process of removing the transmission. all the bolts are off, the tranny is free, it is sitting on the tranny jack, but there is absolutely no clearance to take it anywhere: up or down.
the tranny mount on the left side subframe is removed.
also, i'm having trouble removing the driver's side axle. the passenger's side came out with no problems. what's the trick? thanks.
apudapus is offline   Reply With Quote
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Need Help!! Removing Front Door Panel 98 Camry sk72 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-06-2006 02:51 PM
Who has had transmission problems in a Gen 3 Camry? JSVH 3rd & 4th Generation (1992–1996 & 1997–2001) 51 12-30-2004 03:44 PM
