...ametures, lol.
first figure out if its the belt, or something simple in that area. if you find play in the compressor shaft (or the pully moves in and out) then its prolly shot. do you actually get cool air when the A/C is on? if not then decide to replace it.
you first need the system relieved/vacuumed of the charge thats in it, so you can safely remove your compressor. then replacement, and lastly recharge with the correct volume, and dont forget to add some oil (A/C oil, spesficly).
working at a dealership has its good pionts.
good luck with the work!
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
