93 Camry Tranny problems? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2007, 08:52 AM   #1 (permalink)
View adawg_08's Photo Gallery
I am having problems with my 93 camry. Its a 4cylinder auto. It started this all of a sudden. when you go around a turn slow something pops and snaps like. Not very smooth around turns. Now when going straight it will all of a sudden pull to one side very hard, left or right. It turns really weird now. It is very hard to explain. Around turns at about 30-40mph its very hard to keep straight in your lane. It's got new wheel bearing, cv axles and it still does it. I'm thinking its the differential if it has one? The local shop said tranny problems. Thats as far as they go. Thanks
Does anybody have some exploded veiws of the front end?
Aaron
adawg_08 is offline   Reply With Quote
Old 03-07-2007, 09:20 AM   #2 (permalink)
CamRY GirL Md
View Camry92LE's Photo Gallery
well if the car is pulling it's definitely not transmission problems..
might be the alignment.
*~Jackie~*
Camry92LE is offline   Reply With Quote
Old 03-07-2007, 09:25 AM   #3 (permalink)
View keba's Photo Gallery
1.sounds like the power steering belt slipping...
2.if it has alignment issues it should more or less pull consistently,than suddenly (or) something in the steering assembly is popping out of place,back and forth
keba is offline   Reply With Quote
Old 03-07-2007, 09:33 AM   #4 (permalink)
97 Avalon Silver Spruce
View parimento1's Photo Gallery
Sounds to me like your control arm bushings are shot, put your car up on the lift and check for play. Also check ball joints and tie rods- both inner and outer for play.
parimento1 is offline   Reply With Quote
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
93 camry 5 speed tranny from v6 BAGGEDCAMRY01 Car parts for trade or wanted parts 0 03-06-2007 07:08 PM
90' camry tranny problem nofear4189 1st & 2nd Generation (1983–1986 & 1987-1991) 3 01-05-2006 09:48 PM
signs of tranny problems bowlofturtle Camry & Solara Lounge 1 04-10-2005 01:02 AM
1999 Camry problems nonstop only 28,800mi neuspeed 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-04-2004 12:03 AM
