Sounds Like a rock is in my engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2007, 07:56 PM   #1 (permalink)
View 98Kam's Photo Gallery
Hello, I have a 98 le with the 4 cylinder about a year ago I drove it without enough oil and then it started knocking. It sounds like something is like a bolt or somthing is bouncing around in it. I took off the valve cover and did not see anything wrong. So I drained the oil and did not see anything in the oil. I was thinking about taking off the oil pan next. I have not driven it scince then, it cut off on me back then after I drove it for a while so I didnt want to mess it up worse. Anybody have any suggestions?
98Kam is offline   Reply With Quote
Old 03-08-2007, 08:00 PM   #2 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
View CJ Otey's Photo Gallery
it sounds like you damaged the motor
Two Toned 97 camry w/gen 4.5 front end conversion and 20" wheels and 2 Alpine Type R 15's in a vented box pushed by kicker zx1000.1
CJ Otey is offline   Reply With Quote
Old 03-08-2007, 08:05 PM   #3 (permalink)
I know I damged the motor I want to know if someone knew what part did I damage.
Old 03-08-2007, 08:08 PM   #4 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
you cant tell without seeing the motor it could be anything internal
Old 03-08-2007, 08:40 PM   #5 (permalink)
Does anyone know how to check if the water pump is bad, I heard that might be the problem
Old 03-08-2007, 08:55 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
well u can be assusred that if somthing was bouncing around in the oil pan ur engine prolly would have completley torn itself apart by now. drop the pan and see if there is anything in it, draining wont remove any large chunks of metal. if the water pump was going ud most likley have problems with engine temp. it may be a spun bearing which can happen if the engine is running to dry for a while. hope this helps a little.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-10-2007, 12:21 AM   #7 (permalink)
View mspringer's Photo Gallery
Start looking for a junkyard motor.
If you ran it really low on oil, enough to stall the motor (the engine siezed), stop thinking it might be the water pump. You've wasted the motor. One or more bearings is spun, and this is not a simple repair.
mspringer is offline   Reply With Quote
Old 03-10-2007, 02:20 AM   #8 (permalink)
View toyomoho's Photo Gallery
As TN posters have stated. If you ran out of oil, most likely the engine has internal damage and will need to be taken apart to determine just what. Most likely at least a rod bearing.
Old 03-10-2007, 02:55 AM   #9 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
knock knock..
who's there?
ROD KNOCK, BITCH!
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 03-10-2007, 08:40 AM   #10 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Originally Posted by Razo-E
knock knock..
who's there?
ROD KNOCK, BITCH!
Rod Knock, didn't he do some 'adult' movies in the late 80's?...
Anyways, that's the exact sound my engine was making when I burned up a couple of rod bearings. The noise was very faint at idle, but when I would accelerate, I'd hear it. I would second that you drop the oil pan, that would tell you right there, because just draining the oil might not show you much.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 03-11-2007, 12:00 AM   #11 (permalink)
I has boost..!
Razo-E's Avatar
use a stethoscope on the block, and pull out the spark plug wires one at a time. If it quiets when you pull a plug out, you fount out which one roasted a bearing..
Old 03-11-2007, 09:40 PM   #12 (permalink)
Ok guys the engine did not stall it just started to knock and the noise is sounding like its coming from the top of the engine like the head.
Old 03-12-2007, 01:12 AM   #13 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
knock knock..
who's there?
ROD KNOCK, BITCH!
lol ! I love that one... funny
V6LE_CAMRY is offline   Reply With Quote
Old 03-12-2007, 10:16 AM   #14 (permalink)
View SwampFox's Photo Gallery
Sounds Like A Rock In The Engine
How did you know that the engine was low on oil? Did you see the low oil pressure light come on briefly from time to time? Did you see the low oil pressure light come on and stay on for minutes at a time? How long have you driven with the low oil problem?
1994 Camry V6 SE Coupe
"Fall of the Republic" http://www.youtube.com/watch?v=VebOTc-7shU
SwampFox is offline   Reply With Quote
Old 03-12-2007, 10:18 AM   #15 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Cool
That means that your camshafts are shot from oil starvation.
BlueFusion6851 is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Trouble with transmission after new engine installation vinimack720 Camry & Solara Lounge 5 10-11-2006 09:43 PM
