Originally Posted by tarbasd
This doesn't make any sense. Why did it work for 4 months then? I have no idea what that wire that can be, but I bet this is an unrelated problem.
Maybe you have a contact problem to the instrument panel?
You are right about that. One thing I was thinking about. But the problem came on gradually. The car started shifting worse and worse as time wore on and the techometer started working less and less of the time. BUt it all started 4 months or so after I did the Transmission fluid change.
Now from a cold start I put the car in D and it holds on to 1st gear for a good while just reving higher and higher and then bam it shifts into secound and the od light starts flashing. After that it shifts more normaly. After it warms up the techometer starts working a little and it'll shift breifly in and out of gear. It is exactly like the transmission doen't know what gear it wants to be in.
