threads for oil pressure sender - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2007, 05:04 PM   #1 (permalink)
View donaldd34's Photo Gallery
Does anyone know of the threads for the oil pressure sender in a 94 4cyl Camry are NPT or metric. My oil pressure test gauge kit came with 1/8, 1/4 and 3/8 adaptors, but no metric.
donaldd34 is offline   Reply With Quote
Old 03-11-2007, 05:16 PM   #2 (permalink)
Unco's Avatar
View Unco's Photo Gallery
not sure. try pulling the oil pressure sender out and put it and the test adaptor side to side, you know, like you do with bolts when you want to see if they have the same thread. if you can't get them to line up, then don't use the adaptor.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-11-2007, 05:35 PM   #3 (permalink)
that way of holding bolts next to each other works fine for normal (non tapered) threads, but I do not think it works well for tapered threads (like NPT).
Old 03-11-2007, 06:14 PM   #4 (permalink)
View toyomoho's Photo Gallery
Find the sensor at the link below, then read off the tread type.
http://www.mitechignition.com/pdf/pr...ilPressure.pdf
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
