moaning sound? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2007, 02:16 PM   #1 (permalink)
View se0u1sk's Photo Gallery
moaning sound?
Hi, I just bought a 2000 Toyota Camry LE today. It has 67k on it and looks good. The only thing is, there seems to be a moaning sound. it seems to be coming from somewhere near the air filter area under the hood. anybody know what it could be? I'll try and post a video or something of the sound. also, the car didn't come with the owners manual. so i have a few questions.
1. what is the engine oil does the I4 engine take?
2. how much oil does it take?
thanks!
se0u1sk is offline   Reply With Quote
Old 03-12-2007, 02:39 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
yeah...i hear moaning sounds in my car too, but its usually from the back seat .
since the summer months are commin up id recomend a 20w-40/50 and ud need a little less than 4 gts. 3.8(max capacity) to be exact.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-12-2007, 02:40 PM   #3 (permalink)
View davemac2's Photo Gallery
Does it only happen when the A/C is on? If so, likely the expansion valve and it will to be replaced.
If not, then it may be a vacuum leak or a bad bearing on the auxillary belt somewhere such as the alternator, PS pump, etc.
dave mc
davemac2 is offline   Reply With Quote
Old 03-13-2007, 02:43 PM   #4 (permalink)
Gameroom cash: $303055
1. The generation 4 5SFE 2.2 liter 4 cylinder engine used 5W-30 oil.
2. 3.8 quarts is correct per the manual, but in my experience, after warming the engine to operating temperature and then letting the oil drain for at least 45 minutes, it takes the full 4 quarts.
Mike
Old 03-13-2007, 02:58 PM   #5 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
maybe theres a cat under your hood
Old 03-13-2007, 03:56 PM   #6 (permalink)
alright so today i went out and looked around the car alittle more just to see where everything is and what not. I took notes of things i need to replace/clean. The battery terminal is covered with battery acid. I know there's a way to clean it but is there a way to replace the connector on the teriminal? it's covered in battery acid and i think i'd be a better idea to change that part rather than cleaning it. but if it's fine to just clean it, i'll go that way. Where can i get the parts to clean the battery terminal? I also noticed that the engine seems to be tilted towards the back. is this normal? when i got in and started the car, it hesitated for about 4 sec. after it turned over, the idle was at 2k then dropped to about 1800 rpm after about 15 sec. I'm guessing it's the throttle valve thats sticking. how would i go and clean this or what can be the problem? what is the normal idle range for the camry 2.2L? how much does it cost to get a new key and remote? i have two keys and one remote and would like a second remote and a second key with the black covering. where do you guys get things for your camry? thanks! I'll have the video of the engine sound up but it sounded like a whistle.
Old 03-13-2007, 04:43 PM   #7 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Wow, let's see if I can help you out here...
The engine is tilted towards the back, that's normal.
The engine will idle a little high upon startup, then after 15-20 seconds idle down to normal (depending on the temp, I guess), but I think 1800 is still a bit high. Mine idles around 1000-800 before it warms up.
For the exact idle range, download the factory manual (gen 4) that's located at the top of the General Camry Discussion section.
If you want a new key and remote, you might be able to find a blank key on ebay and have it cut, and I know you can buy replacement remotes from AutoZone. I still think you have to take it to the dealer to get it programmed (I could be wrong).
As for things for our Camrys, what exactly are you talking about? accessories? parts? window stickers? doo-dads? Some people only swear by OEM (Original Equipment Parts - Dealership). I myself will get some items from the dealership (o-rings, seals, gaskets, Toyota filters, antifreeze) but usually get my reman stuff from auto part stores. You can also find stuff on ebay or occasionally people here are parting out or selling stuff from their projects (seems to be a lot of that in the way of Camry's lately...)
As for the battery acid, you could always do the ol-fashioned way of pouring coca-cola on it to dissolve the acid corrosion, then take the terminal off the battery (you really should do that first anyways), take a metal brush and scrub the heck out of it. When you get it shiny and decent again, get some battery protectant gel or spray and coat it very well after putting it back on the battery post.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 03-13-2007, 09:57 PM   #8 (permalink)
like oem parts and accessories for the car like floor mats and maintenance parts
Odd Whirring Sound 94 Toyota Pickup SR5 4x4 pickup sr5 89-95 Toyota Pickup/Hilux 2 02-17-2006 06:40 AM
odd sound kadsworld xB Lounge 3 02-05-2006 06:41 PM
moaning sound from steering jason0618 Camry & Solara Lounge 4 01-13-2006 08:40 AM
Moaning sound at highway speeds yaitisme Tercel, Paseo, Starlet, and Sera Forum 4 09-26-2005 07:17 PM
HELP..weird squeaky sound coming from tires Tubbyc Camry & Solara Lounge 6 04-20-2004 01:35 AM
