Max Rim and Tire size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2007, 09:09 PM   #1 (permalink)
CamryRider
nemiz's Avatar
View nemiz's Photo Gallery
What would be the maximum rim size I could put on a camry v6, without lowering, all stock.
Would 18's be safe? So if I go with 18's which tire size can I go with, and also how wide can the tire be? Also just in cast if I would lower the car after would the rims still fit?
If I lower the car 1.7" Will I have to do anything to the suspension to have the wheels run straight, I mean not on an angle (/)---(\) << Like that. If i only but the lowering springs do i also have to change the shocks?
If anyone could answer my questions?
Thank you
a n d r e
nemiz is offline   Reply With Quote
Old 03-12-2007, 09:30 PM   #2 (permalink)
View thereal2x's Photo Gallery
i have 215/45/18 rims and tires with a 35+ offset on my 99 camry and i have no problems with fitment. im not sure about lowering tho. some poepl on this forum have 20s but thier tires are really thin and would probably sacrifice alot of ride comfortability
thereal2x is offline   Reply With Quote
Old 03-12-2007, 10:18 PM   #3 (permalink)
CamryRider
nemiz's Avatar
Ur car looks good on 18's.
Thank you
a n d r e
Old 03-12-2007, 10:40 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
18s would look good lowered or stock and u should get an alignment after u lower it, i have a 2"drop about and didnt need camber plates, just an alignment. if u leave it stock u could do almost any size wheel but anything above an 18 is a waste.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-13-2007, 01:02 AM   #5 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
u dont want to goto the max, it starts to look really cheesy - a nicer pair of well-fitted rims will make your car look the best
i would say 16" or 17" rims ... and the sidewalls,etc. is basically up to the limits of your car
Old 03-13-2007, 03:56 PM   #6 (permalink)
View woody89's Photo Gallery
Sorry to thread jack, but what is the max width tire you could fit? 245/35/18 be to wide? He said he beleives the rims are about 10" wide. :/ That's just a guess though, I'm trying to get him by to actually measure them.
woody89 is offline   Reply With Quote
Old 03-13-2007, 04:13 PM   #7 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I agree with Venom, I personally dont like cars that have rims practically up to the sidewall, but rather a slightly larger then stock look, so it doesnt look cheesy, and still looks presentable (not rice-like).
geoff5093 is offline   Reply With Quote
Old 03-13-2007, 05:17 PM   #8 (permalink)
View projectcam2's Photo Gallery
well i have 19" on mine
and im not to happy with the amount of space i have at stock level.
it just alldepends on your taste.
but my max is my 19/8.5
235/35zr
http://www.cardomain.com/ride/2433231/1
<A href="http://[size="2/" target=_blank rel=nofollow>www.myspace.com/distinctdesigns07
projectcam2 is offline   Reply With Quote
Old 03-13-2007, 05:22 PM   #9 (permalink)
I'm Cam'd Up
Pimpinda93camry's Avatar
View Pimpinda93camry's Photo Gallery
thorw some d's on that bitch....
id say you can get 20's but like said befor it would have ruber band tires and it couldnt be wider the 9.5 or ten at max. but i did see a guy on cardomain that had 22's but he as even going to get 24's
****NEW 1970 CHEVY NOVA**** MORE INFO LATER
Cold Air Intake
Cat Back Muffler, 5% Semi Matelic Tint
16x7 Proline Alloy, Dunlop SP FM901 225/50/R16
Clarion HU, JL Slash 500/1 , 2 JL 10W0, Silver Star Headlights
Pimpinda93camry is offline   Reply With Quote
Old 03-13-2007, 09:09 PM   #10 (permalink)
View 01camryCE's Photo Gallery
I realize you want to know the max and not everyones opinion. With a ridiculous amount of searching to find this information(which isnt much) I will supply you with what I do have.
You can go as large as 20's if you want, it is all about having the proper offset to make this work. If your offset is to low, say + 50, you may not even be able to put the wheel on the hub to bolt it on. The wheel/tire would hit the strut and it just wouldnt work.
Now, if you go with a higher offset like +35, you can fit many wheels up to 20's on there.
I will tell you what I have found to be a comfortable(within reason) size wheel and tire for the camry from 97-01.
18's for example will fit, but only if the rim is 7 or 7.5 inches wide and the offset is between say +35 to +42, 42 is questionable, so +40 would be more where you would want to be.
That applies to any of the other size wheels. You get to wide and the offest to low, you will not even be able to put them on. Or if your offset is to high, you may get the 8 inch wide rims to fit but the outer wall of the tire will rub on your fender.
Keep searching and reading. Here is a thread that will help you some, but You may gain more info from my post, either way, read up, it will help.
Lets Talk offsets !!! my friends
Mattster
01camryCE is offline   Reply With Quote
maximum size of tire for a 16 inch rim? Matus1 89-95 Toyota Pickup/Hilux 2 07-17-2009 05:16 PM
Max tire size for new Rim jadamjr 2nd Generation (2005+) 1 10-05-2006 07:27 PM
What size tire on a 16" or 17" rim pasty64 Tercel, Paseo, Starlet, and Sera Forum 1 11-11-2005 10:58 AM
Rim + Tire size and speedo change Giant81 Camry & Solara Lounge 2 02-07-2005 03:49 PM
