96 camry 2.2, has spark and gas. No Start
Hello,
Im having some trouble getting my 96 camry to start. I have checked all the fuses, relays, timing belt is in tack (rotor is spinning while cranking), there is spark at the spark plug wires, fuel at the fuel filter, and timing seems to be alrite. I tried to get the car into diagnostic mode, but it won't enter into it. I thought for sure this was a good sign that the ecu was bad, so I swapped out a working unit, and still a no go. The car would not enter diagnostic mode with the new ecu either! Im stumped on this one. I can't seem to figure out why the car won't enter diagnostic mode. When i jump the two terminals, turn the key to on, the check engine light stays solid. I even tried the diagnostic port under the dash, same situation.
I can crank the car over, but it does not start. The tach will sit at 250 rpm and not budge. The car drove fine, then 5 hours later it started for less than 5 seconds and died, and it still sits. Anyone have any ideas? Im thinking perhaps the crank angle sensor, I have ordered one but would hate to use it if its not the issue. (expensive part!) any help would be great. I will be taking the two hour trip again thursday or friday to attempt to get the car running again.
thanks,
Mark
