Re-gasket engine, need suggestions
I have had a persistent oil leak for a while. I have tried different items but cannot resolve the leak. I would like to stop the leak so I can park in my driveway without leaving spots. Also, it has been 66,000 miles since last timing belt change. With both the timing belt and oil leak, I am contemplating pulling the engine and trans to re-gasket the engine. I would be looking at replacing the front and rear main seals, camshaft seal, oil pump seal, water pump gasket, distributor o-ring, oil pan gasket, and valve cover gasket. Is there anything I am missing or should add to the list? I have looked at complete gasket kits for the 5SFE and they include a head gasket. Should I do the head gasket or not?
What seals / gaskets should I do on the transmission while it is out?
Is this crazy to attempt with a car that has 224,000 miles on it? I am open to ideas / opinions.
