95 Camry with no back up lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2007, 06:51 AM   #1 (permalink)
View classicr's Photo Gallery
3rd Generation 95 Camry with no back up lights
This car belongs to a friend of mine and I havn't seen it yet but she said she hasn't had back up lights for the last couple of years. I was hoping someone had a little insight on what this might be before I get a chance to look. She said her dad looked at it once so I'm assuming he checked the easy stuff, ie bulbs, fuses, ect...
Thanks in advance.
classicr is offline   Reply With Quote
Old 03-15-2007, 05:45 PM   #2 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
It's either a break in the wiring which is near the trunk hinge or the reverse neutral safety switch. If I'm not mistaken, for the latter, the "R" indicator on the gear selector in the dash will also be out if the reverse lights aren't on. This is what happened to my mom's Camry. If ithe "R" indicator is still on and works, I'd learn toward the wiring in the trunk.
Good luck!
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 03-15-2007, 06:06 PM   #3 (permalink)
4th gen 2000 camry ce
View HOOKEDonLP's Photo Gallery
on my 2000 camry.
i took it to a mech. and he did some test on a sensor. and it turned out tat it was broken. and tat was the problem to my reverse lights. it was located under the hood. i dont anymore than tat. sorry.
HOOKEDonLP is offline   Reply With Quote
Old 03-16-2007, 07:41 AM   #4 (permalink)
Hey thanks guys. I havn't had a chance to look at it yet but I'll start here.
Old 03-16-2007, 08:12 PM   #5 (permalink)
R/C Junkie
View Smiff 24's Photo Gallery
I have a 94 that had the same problem, check inside the trunk, beside the left hinge.
youll have to pry open the flexable conduit, my wire was pulled apart there .
I spliced a short piece of wire because the two ends wouldnt hardly come together.
94 camry le 4 cyl.
Smiff 24 is offline   Reply With Quote
Old 03-17-2007, 12:48 AM   #6 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Also, DO NOT overlook the obvious. Make sure the bulbs are still good.
5 Lug Corolla WHAT?
Old 04-01-2007, 07:47 PM   #7 (permalink)
Thanks
Just wanted to thanks every one. It was a broken wire by the left hinge. Easiest find in a long time. Took me a while to get the car here to look at it. Your friends are always so happy when you fix thier cars. Specially after two years.
2000 Camry Trunk Tail Lights Not Functioning ds_1910 3rd & 4th Generation (1992–1996 & 1997–2001) 12 04-19-2008 07:03 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
New 95 camry 2dr 4cly onle 73K miles!!!! nik99 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-16-2006 01:46 PM
95 corolla back lights lilmadafaka Archived Corolla threads 7 02-28-2005 04:59 PM
95' V6 Camry Back Box/muffler/exhaust tizer2000uk 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-14-2004 05:57 AM
