Bolt sizes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2007, 09:20 AM   #1 (permalink)
View nevanerviss's Photo Gallery
Bolt sizes
Would someone please tell me what size sockets/wrenches are involved with taking off the front wheel hub assembly?
nevanerviss is offline   Reply With Quote
Old 03-16-2007, 09:47 AM   #2 (permalink)
I'm Cam'd Up
Pimpinda93camry's Avatar
View Pimpinda93camry's Photo Gallery
21mm 14mm 17mm and i think the driveshaft is a 30 mm or 28mm
****NEW 1970 CHEVY NOVA**** MORE INFO LATER
Cold Air Intake
Cat Back Muffler, 5% Semi Matelic Tint
16x7 Proline Alloy, Dunlop SP FM901 225/50/R16
Clarion HU, JL Slash 500/1 , 2 JL 10W0, Silver Star Headlights
Pimpinda93camry is offline   Reply With Quote
Old 03-16-2007, 10:56 AM   #3 (permalink)
Thanks a lot... Which size needs to be deep well?
Old 03-16-2007, 11:28 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
driveshaft is 30mm.
Old 03-16-2007, 12:30 PM   #5 (permalink)
Thank you so much guys... One other question: what size wrenches do I use to get the caliper off?
Old 03-16-2007, 01:33 PM   #6 (permalink)
Gameroom cash: $303055
14MM for the caliper itself. 17MM to remove the caliper mounting bracket (also called the torque plate).
Mike
Old 03-16-2007, 06:28 PM   #7 (permalink)
The reason for these questions is ALL but one of my studs broke off my right front wheel... Actually, there were two, and the guy who towed my car took the liberty of breaking the other one while he was putting the tire back on (I had taken the wheel off)... I didn't know it, and parked the car when I felt it shimmy and making a loud noise... There were no steering issues, though, which was strange... From reading the repair manual, I need to remove the wheel hub assy. to get more studs, so I figured I may as well change the whole thing, not just the studs... Is that a good idea? It seems like a pretty straight-forward process, but is it difficult to do?
Old 03-16-2007, 08:42 PM   #8 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Originally Posted by ghettosled
driveshaft is 30mm.
CV axle
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 03-16-2007, 08:57 PM   #9 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
You don't need to remove the hub to get out a stud, it just makes it much easier. Take off the caliper and rotor, then drive out what's left with a heavy hammer (and a punch if there's nothing there to hit). To put the new stud on (they should be M12 X 1.5 - 40mm), get it situated in the splines from behind and stick it through the hole. Then, take some washers the same diamter (I'd recommend enough to just give the lug nut a few threads) and an old lug nut and tighten the hell out of it until it presses the stud into the hub. It really works if you've got an impact wrench (air or electric, you just need a quick burst of torque). When it's fully seated in the hub, you can loosen the lug nut, remove the washers, and you're done. I had to replace two studs when I got my car, and that's how I did it. I just bought longer studs to accomodate my new wheels and that's how I'm going to put them in, too.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 03-17-2007, 01:02 AM   #10 (permalink)
ghettosled's Avatar
Originally Posted by GrkBallaG
CV axle
r
whoops - wasnt thinking
Old 03-17-2007, 08:37 AM   #11 (permalink)
Where would I get new studs from? The car is in my job's parking lot, and while I can (and will) go and buy an electric impact wrench, I don't have access to electricity for it...
Old 03-17-2007, 09:58 AM   #12 (permalink)
Quasi-Evil Monkey
renmike's Avatar
You can buy wheel studs at most parts stores, I think the stock Dorman P/N is 610-266. I did not realize that you're car's in an unconvenient location, I was just suggesting what you could do instead of buying a whole new hub. Using an impact is the quickest way of pulling the stud back into the hub, that's why I suggested it.
Old 01-16-2009, 04:23 AM   #13 (permalink)
View nuron's Photo Gallery
I will be doing this on my dad's 99 soon, which has a broken stud. Do I need to put any compound on the new stud before putting it back on?
nuron is offline   Reply With Quote
Old 01-16-2009, 08:48 AM   #14 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Just make sure the hole is clean, the stud's splined section is designed as an interference fit, so it will be very tight.
Unless you do not have power tool I would leave it dry.
If you must use a lube, like doing this by hand tool, get a tiny bit of tapping oil, or anti-seize, something with extreme pressure lubricant (Moly graphite, etc).
Look into loctite retaining compound which will aid in assembly. It also reduces vibration wear and seals out moisture, but really overkill.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
1988 3s-fe, 8 Bolt Vs 6 bmills4 1st & 2nd Generation (1983–1986 & 1987-1991) 11 09-09-2006 04:33 PM
Roll Bar kits Just $169.95! Bolt in kits start at just $269.95! From Safedrives.com Safe Drives Supporting Vendor Sales 10 10-13-2005 05:04 PM
Sway Bar Bolt Sizes Calvin327 Camry & Solara Lounge 4 09-30-2004 12:30 AM
Celica/MR2/Camry 5sfe 6 bolt or 8 bolt crank??? Talisman General Discussion 2 06-12-2004 01:48 PM
