Serious gas tank problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2007, 10:09 PM   #1 (permalink)
View bluerooFAIRLANE's Photo Gallery
My mom has a 98 Camry LE, 2.2L 4 cylinder, auto. Lately it's developed an EXTREMELY annoying problem. When you fill the tank, you have to dribble the gas in otherwise it splashes back up and hits the automatic shut off on the gas pump nozzle. A quarter tank will take at least 10 minutes.
My dad and I pulled the filler neck, there were no obstructions whatsoever. The valve on the tank body moved freely. The other day we took the car to a shop and blowing compressed air through the lines did nothing as well.
Can anyone offer any insight as to what might be causing this?
1964 Ford Fairlane 500, "Misty Blue"
bluerooFAIRLANE is offline   Reply With Quote
Old 03-19-2007, 07:36 PM   #2 (permalink)
View lenjack's Photo Gallery
It is likely that the charcoal cannister is saturated with liquid gasoline. It is only designed to absorb gasoline fumes. The usual cause for this is habtually topping off the tank after the pump clicks off. Trying to get those last drops of gas into the tank, will force the excess into the cannister. Dealer repair on this is probably over $300...maybe $400! We had the exact same thing on the exact same car.
lenjack is offline   Reply With Quote
Old 03-20-2007, 01:24 AM   #3 (permalink)
View toyomoho's Photo Gallery
The tank needs to vent when filling with fuel. There should be a vent line(s) going from the top of the fuel tank to the top of the fuel intake pipe (where you put the fuel in). See if these pipes are pinched or plugged.
gas tank slow to fill vrickster 3rd & 4th Generation (1992–1996 & 1997–2001) 5 07-03-2009 08:32 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Gas tank: Fill problem at the pump JJimmy Solara 7 02-23-2007 10:01 AM
CEL on with full tank and off with half tank of gas quagga 3rd & 4th Generation (1992–1996 & 1997–2001) 0 02-14-2007 06:02 PM
Gas sediment inside the tank hdsalinas Archived Corolla threads 4 06-09-2004 03:01 AM
