Wont start! help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2007, 10:42 PM   #1 (permalink)
View SilvaCam92's Photo Gallery
Wont start! help!
so i try to start the car after i drove home from work, and it doesnt start. the starter doesnt click, i have power (horns and lighst work) and the relays are working but the starter doesn do anything. could the starter maybe disconnected?
3/24/12 - 250,000 miles
http://www.cardomain.com/ride/2593921
SilvaCam92 is offline   Reply With Quote
Old 03-18-2007, 01:34 PM   #2 (permalink)
Originally Posted by JJJJJJ
shift to neutral and try starting it.
possible neutral safety switch failure, contact wear, bad ground, or path to ground in battery.
has real estate crashed yet in MA ?
tried the neutral thing. didnt work. i think its the starter/solinoid. i tapped the starter and it started up so...
and no i dont think real estate has crashed yet
Old 03-18-2007, 02:27 PM   #3 (permalink)
Gameroom cash: $303055
Here's a link on replacing the starter's solenoid contacts that you might find useful:
http://www.automotiveforums.com/vbul...d.php?t=166530
Mike
Old 03-18-2007, 09:39 PM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
have you tried smacking the starter? if there's a bad spot, smacking it with something like a tire iron will move it to a different spot that it can get contact. also check the wire to make sure something isnt loose or corroded.
Old 03-19-2007, 07:42 PM   #5 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
umm...thats what he said he did.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
2001 Tacoma won't start HotRodd38 1st Generation (1995.5–2004) 6 11-12-2007 03:44 PM
Start and go ? I don't think so. Mike-in-WV 1st Generation (1995.5–2004) 30 08-01-2006 08:51 PM
01 Rough Idle, Stall, Hard Cold Start anr 3rd & 4th Generation (1992–1996 & 1997–2001) 0 05-30-2005 12:50 AM
Click sound from under the hood..won't start snobdrblinkchik Camry & Solara Lounge 10 08-22-2004 09:04 PM
