It depends entirely on the exact transmission you talk about. There are over a dozen varryations of what is pretty much considered just 4 transmissions.
The 3s-gte's E153 can be used if the linkage is swapped. Keep in mind the differential, and gearing are different than the transmission actually mated to the v6's. It will cause alot more frequent shifting. Keep that in mind...
AFA any of the S transmissions. Yes you can mate them. If Toyota thought the S transmissions could hold 150ft-lbs of torque, they would have never created the E51 for the 4a-gze, or the E52 for the 2vz-fe. There is no question if an S family transmission can tolerate the torque output of a v6 for more than a short term basis. It's been done several times before, it's yet to work long-term...
AIM/Yahoo Toysrme257th
Now with Turbo!
