Change springs as well as shocks? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2007, 03:18 AM   #1 (permalink)
View toyotarave's Photo Gallery
4th Generation Change springs as well as shocks?
Hello
Just changed all 4 shocks for my 99 Camry - is it advisable to change the springs as well - the ride now is very much better than before the change - guess all the shocks were worn out after 6 years on the road - will I experience an even better drive with new springs -
BTW I checked ebay and only springs available were lowered down OEM springs - no stock springs anywhere?
Cheers
toyotarave is offline   Reply With Quote
Old 03-19-2007, 03:23 AM   #2 (permalink)
Unco's Avatar
View Unco's Photo Gallery
i don't think you'll notice much difference unless your current springs are sagged or somehow damaged. but if you're going to go through the trouble of replacing them, you might as well put lowered springs in it and THEN it will make a difference because the ride height will be affected. having said all that, you probably should have done it all at the same time you changed the shock absorbers.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-19-2007, 08:46 AM   #3 (permalink)
Camryshowoff97
View Camryshowoff97's Photo Gallery
Stock springs arent worn out anywhere near as fast as the shocks, unless you have done some serious abuse to them to crack them or anything like that id say your ride right now is at its best without wanting to swap out for performance springs and shocks.
Camryshowoff97 is offline   Reply With Quote
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
New Shocks and Springs! jbirdy958 Camry & Solara Lounge 6 02-08-2006 09:39 PM
