oil pressure problem on 94 4 cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2007, 03:41 PM   #1 (permalink)
View donaldd34's Photo Gallery
Problem started with oil light flickering, found oil was low, but still between ADD and FULL. Added some oil and brought it up to FULL. Went on my way, and after another 10 minutes the oil pressure light again flickered.
Got home and the next day (cold) screwed in a mechanical gauge and started the engine and the pressure slowly rose up to 15 but stayed there ragardless of RPM, Restarted the engine and now the pressure goes to 20 and then varies with RPM up to 50 at 3000RPM.
Have tried this on 3 different days with engine cold and swapped in a 2nd mechanical gauge. Always the same result.
The engine has always been run on synthetic oil so I would not suspect sludge or varnish.
Has anyone come across this before?
donaldd34 is offline   Reply With Quote
Old 03-19-2007, 05:09 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
oil pump?
HaHa
Old 03-19-2007, 06:38 PM   #3 (permalink)
When the oil pump goes it produces low oil pressure. This seems to be an odd startup oil pressure problem. It could be a sticking oil pressure relief valve, but should not happen given that the engine has always seen synthetic oil.
94 oil pressure problem 94toyput 89-95 Toyota Pickup/Hilux 8 08-17-2006 11:01 AM
88 High oil pressure problem 92_Gen3_5SFE_LE Supra Forum 6 07-21-2006 11:08 AM
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 04:32 AM
Oil Pressure sensor/switch lcarocha General Discussion 1 07-06-2005 05:22 PM
