My 96 V6 viberates bit more when gas is low? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-19-2007, 04:17 PM   #1 (permalink)
View shanzhu1's Photo Gallery
When put auto shift in "D" and stop, I feel more shaking on the steering wheel
when gas is low (1/3 or lower). Quite strange??
Anyone knows a cure?
Thanks lot.
SZ
shanzhu1 is offline   Reply With Quote
Old 03-19-2007, 04:24 PM   #2 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
4th Generation
dont let ur gas get that low...u will make the fuel pump heat up
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 03-20-2007, 08:16 AM   #3 (permalink)
View CrazyCamry's Photo Gallery
care to explain further?
Giving up racing is the easiest thing in the world. I know, because I've done it thousands of times
Gen 3 200si (yes, Gen2, 3sfe in a Gen3) factory stock,
CrazyCamry is offline   Reply With Quote
Old 03-20-2007, 08:25 AM   #4 (permalink)
Unco's Avatar
View Unco's Photo Gallery
first of all, the fact that you're feeling shaking at the steering wheel is more indicative of worn/broken engine/transaxle mounts than anything else.
as for the shaking itself, i don't think it would be caused by your fuel level, probably more to do with the engine temperature in conjunction with the state of your IAC valve and throttle body housing... try cleaning them out.
and as for an EFI's system fuel pump running hot because the fuel level is low would only apply if the Gen4 has a wet pump.
not being familiar with the Gen4, i don't know if it has a wet pump or not. but AFAIK all wet fuel pumps work fine until you actually run OUT of fuel as they have their own reservoir within the fuel tank. it would be ridiculous of manufacturers to design a fuel system that would put a fuel pump's efficiency at jeopardy when the fuel level got down to 1/3.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-20-2007, 09:09 AM   #5 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
I'm thinking this has to do with front vs rear weight balancing; the fuel is gone, the rear is lighter, the front is taking more on more weight, that could be leading to your mounts feeling extra stress, i.e. more vibration. I know when I got mine, I had excessive vibration at the steering wheel, I'm still to replace all the mounts, but the best remedy I've found myself is to make sure the timing is set right. Mine was a few degrees off and when I got it in time just right, it vibrated but nowhere near what I had originally.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 03-20-2007, 09:18 AM   #6 (permalink)
Thanks for reply. It puzzles me too. The shaking I meant was not that bad at all.
I just feel it vibrates a bit more just like a normal car with AC turned on.
I am just wondering that, if there is anything in the car that will use the fuel
level as input to adjust the engine speed or anything.
You mentioned engine temp, IAC and TB. I don't think they are related to the
gas level, right?
By the way, I did TB and IAC cleaning couple months before using seefoam deep
creep. I did not notice much difference.
Thanks again.
SZ
Old 03-20-2007, 09:21 AM   #7 (permalink)
Unco's Avatar
gas level, right?
right. they are not related to the gas level at all. the reason i mentioned them is because that's the usual cause for engine idle to drop down lower than standard whicn in case causes more 'shaking' than normal.
not on a toyota camry, no. but other manufacturers have implemented such measures... usually on cars worth a LOT more than a toyota camry.
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
96 Camry V6 LE: TRD supercharger? kman10587 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-16-2004 03:15 PM
