Yep, just went through changing it on my 4cyl Camy... Piece of cake!
What I had to remove/unbolt:
-Air box.
-Fuel filter.
-Both battery terminals
-Driver's side strut from the ball-joint
-Plastic cover between driver's side strut and trany
-Driver's side trany mount
What I had to change:
-Clutch assembly... duh...
-Couple of seized bolts
-Trany oil
Tools required:
-Lift, fork lift with fork's extensions as an alternative or jacks with jack-stands... Obviously the real garage lift works the best, as I had to lift/lower the car on numerous occasions.
-Good, I mean good set of wrenches/sockets with different ratchets and extensions
-Hummer
-Drill to drill out seized bolts...
-Some anti-seize compound
-Some grease to lube the fork, I've used a brake caliper-specific grease...
Total time for a team of 2 guys one of which had previous clutch-change experience:
5 hours
Time it should take in an average garage to an average mechanic: 4-6 hours
800 to 1500$ they charge in most garages is totally not justified... sort of "stand on your knees, bend over and get shafted!!!"
Result:
Clutch pedal feels weired, quite soft... but it's new....
Castrol Syntec gear oil====>
Good stuff!!! Shift feel has improved quite a bit!!
Somehow I feel that my next car will be RWD or AWD... With all these JDM rides getting imported in Canada - I'm tempted by MK3 TT Supra with tagra top...
Time spend with your dad working on your car ==> priceless!!!
