Engine oil leak - (picture) what is this? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2007, 07:46 AM   #1 (permalink)
DLo
You make me stupid.
View DLo's Photo Gallery
3rd Generation Engine oil leak - (picture) what is this?
I am leaking some oil from this (sensor I believe) and wanted to know what it was.
Thanks gang,
Poppa
DLo is offline   Reply With Quote
Old 03-20-2007, 07:53 AM   #2 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Oil Pressure Switch
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 03-20-2007, 08:01 AM   #3 (permalink)
DLo
You make me stupid.
Is it common for the Oil pressure switch to leak?
Does that mean it is gone or is this a simple can be tightened? I didn't mess with it or go at it with a pair of channel locks till I found out what it was. (Been down that "Yea, I broke it not knowing what I was doing" road to many times.
Old 03-20-2007, 08:15 AM   #4 (permalink)
Unco's Avatar
View Unco's Photo Gallery
yes, it is a relatively common replaceable item. a new part should cost very little $$$. make sure you know how to tighten it though. overtightening can cause cracking at the housing as it is not a standard thread... it's tapered.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-20-2007, 08:22 AM   #5 (permalink)
DLo
You make me stupid.
This is exactly why I took the picture, messed with a quick MSpaint and posted it on here BEFORE I grabbed the gloves and pliers.... Thanks man.
And as for price, I did find them here and there for like $5-$12 either used or new so again, thank you.
Old 03-20-2007, 02:03 PM   #6 (permalink)
Quasi-Evil Monkey
renmike's Avatar
3rd Generation
Before you thread the new one on, put some teflon tape on the threads (just a little, maybe 1-2 passes). And do be careful, it doesn't take much to crack it by overtightening it.
Old 03-20-2007, 03:30 PM   #7 (permalink)
DLo
You make me stupid.
Thanks, gonna order one off ebay when I get home and already got some teflon tape at the house.
Old 03-20-2007, 08:59 PM   #8 (permalink)
71Corolla's Avatar
Gameroom cash: $548250
View 71Corolla's Photo Gallery
Don't put teflon tape on the threads. It's not needed, the factory doesn't do this, you don't need to either. Tighten it a moderate amount and check for leaks. If all okay, make sure to check for leaks in a week or 2.
BTW it is common for leaks to develop on the sending unit. Oil usually leaks between the connector lead and the plastic.
71Corolla is offline   Reply With Quote
Old 03-20-2007, 09:45 PM   #9 (permalink)
Unco's Avatar
the factory doesn't put teflon tape on any threads period. i can't really see any harm in putting some on.
Old 03-21-2007, 07:26 AM   #10 (permalink)
Quasi-Evil Monkey
renmike's Avatar
3rd Generation
I've always put a layer of teflon tape on sensor and sending unit threads, especially when you're threading a type of metal into a different type (brass/steel into aluminum, for example). I'm not saying it HAS to be done, it's just a rule of thumb I always follow. If it's good enough for Komatsu and Cummins, it's good enough for me. The biggest problem people have with teflon tape is when it's applied half-ass; either they put it on too thick and have problems threading it or they just apply it sloppy and it ends up getting caught in the passage of whatever it's threaded to.
And just because they don't do it at the factory doesn't mean when you go putting something on 200k miles later that it couldn't use that little bit of extra protection.
So, here's my final word. You DO NOT have to use teflon tape, but please put something on the threads so that you don't have an issue if the sending unit ever needs to be removed.
looking to buy a 88 Supra(california Emissions) chi-toy Supra Forum 3 12-09-2007 08:09 AM
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 09:19 AM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
93 Camry 2.2L engine oil leak tsunami_55 3rd & 4th Generation (1992–1996 & 1997–2001) 7 04-02-2005 09:48 AM
