HI,
My camry with 150k LE 97 4cyl is lately causing some issue. When i start the car from cold and start driving (before the quiet idling), the gear stays in first and does not seem to automaticaly shift. At the same time ofcourse the RPM shoots up as the gear does not shift. Once the car reaches the idle 50% temperature mark, the transmission works normal.
i admit that the last major service i had done by the delear was at 70K and none since
however i do change the oil on regular 3k intervals.
Can someone shed some light on the transmission issue ? THanks
-Ravi
