Advice on Rear Main Seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2007, 12:34 AM   #1 (permalink)
View louie1086's Photo Gallery
3rd Generation Advice on Rear Main Seal
hey guys, i need some advice about my oil leak problem. its been determined by a trusted mechanic that the dreaded REAR MAIN SEAL has given, along with several others in that vicinity. the leak is moderate. the estimated cost was 500-600 and change to fix the leak.
my question, is it worth it? current mileage is ~129,xxx with no other significant problems. i would like to keep this car since ive seen many others with >200,000 miles and still running.
also, i am in college with an air tight budget.
any advice would be appreciated, so thanks in advance.
louie1086 is offline   Reply With Quote
Old 03-23-2007, 12:59 AM   #2 (permalink)
5S-FU
View Sniperdude's Photo Gallery
My mileage is 119,000 and mine went along with valve cover gasket and distributor o-ring. Whole thing cost me 800. Worth it.
Sniperdude is offline   Reply With Quote
Old 03-23-2007, 03:44 AM   #3 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Mine was replaced years ago at around 100K. Now have almost 250K miles so was it worth it? Duh! But you could have it totaled tomorrow so it's one of those "you pays your money and you take your chances" things. BTW, they replaced it twice because it shelled immediately when they started it up.
Dave's is offline   Reply With Quote
Old 03-23-2007, 10:26 AM   #4 (permalink)
Corsulian's Avatar
View Corsulian's Photo Gallery
Most of the people that have them running still at 200k fix those sort of things.
For example, I fix nothing and don't expect more than 125k (tight budget as well--had car through college--and previous owners did more damage than I care to imagine)
So, fix it now if you want to be one of those people. Or don't, graduate, cross your fingers, get a nice Scion tC when you have a swell job. But now I'm projecting.
"If you knew all, you would pardon all"
Corsulian is offline   Reply With Quote
Old 03-24-2007, 12:45 AM   #5 (permalink)
View repapyob's Photo Gallery
Louie, Camry's tend to have their seals start to go all at once. I just did the rear main in my 92 myself. It's not just a job, it's a nightmare! The entire suspension has to come out, along with the subframe, as there is no other way to get the tranny out and there's no clearance. Be SURE to have your cam seals replaced EVERY time you do the timing belt as well. It's ony a few minutes more plus about $30 for the seals and well worth it. I am now sorry I did not, and have to basically do the job again.
repapyob is offline   Reply With Quote
Old 03-26-2007, 05:35 PM   #6 (permalink)
View Boston Redneck's Photo Gallery
If you are going to have it replaced, make sure you have the metal rear main holder pulled and sealed as well. (It's just 5 little bolts that hold the rear main)
Also, there is an oil galley plug just above it and to the right that has been known to leak. It takes all of 3 minutes to pull it, re-seal and install it.
Boston Redneck is offline   Reply With Quote
Old 03-30-2007, 09:04 PM   #7 (permalink)
Hey Bostonredneck, thanks for the tip on the plug. I would have missed that!
Old 03-30-2007, 09:50 PM   #8 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
i would fix it if u want to keep your car cos it will cause more issues in the long run
change the other seals / gaskets around there too
skewe is offline   Reply With Quote
Old 03-30-2007, 10:43 PM   #9 (permalink)
thanks for all the great advice everyone. but for now i think im just going to leave it for now, since i dont have the funds for the repair.
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
rear main seal---tranny removal? profuse007 Camry & Solara Lounge 8 03-30-2007 09:25 PM
Rear Strut Replacement - Need advice!! 89_3SFE Celica Forum 3 07-30-2004 11:33 AM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
95 ES 300 rear main seal leaking " again" 67stinger General Lexus Discussion 3 04-08-2002 12:57 AM
