Door sag problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2007, 01:19 PM   #1 (permalink)
View zirconx's Photo Gallery
Door sag problem
My drivers door is sagging. Its enough that you have to shut the door pretty hard to get it to shut all the way.
I know a lot of domestic cars have a replacable pin and bushing in the hinge. Anyone know what the toyota hinge is like? Can I replace the pin & bushing, or does the hinge unbolt, or - worst case - you have to cut off the hinges with a torch and weld new ones on...
thanks.
zirconx is offline   Reply With Quote
Old 03-23-2007, 11:12 PM   #2 (permalink)
View toyotabob's Photo Gallery
Pretty sure you need to remove the front fender, and adjust the door hinges accordingly. I did this on another car, and I found the keys to be using an assistant, loosening the hinge bolts just to the point you can readjust, and finally, patience.
toyotabob is offline   Reply With Quote
Old 03-24-2007, 10:16 AM   #3 (permalink)
In Tents
ToyCam187's Avatar
View ToyCam187's Photo Gallery
Like is it sagging a little or a few inches, because my friend had this problem with his car and all we did is...
Open the door, put a jack under the opened door (with a rag) Loosen the "door stop strut bolt" (Black hinge with a bump in the middle). Then loosen the other hinges. Jack the door up little by little, keep tightening the door, and checking if it shuts. Like toyotabob said ^ patience.
ToyCam187 is offline   Reply With Quote
Old 03-25-2007, 03:57 PM   #4 (permalink)
Its sagging about 1/2 an inch. If I post a picture maybe you can tell me what bolts you are talking about? Not sure what you mean by the "door stop strut bolt". The brackets that are attached to the door, that hook into the hinges?
Electric problem! Please help!! 1987SR5 Pre-88 Toyota Pickup/Hilux 2 12-02-2005 09:58 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
