Gen 3 just started missing-1MZ-FE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2007, 11:22 PM   #1 (permalink)
View toyotabob's Photo Gallery
3rd Generation Gen 3 just started missing-1MZ-FE
My 1996 (just started missing after I thew it in reverse(just after starting). Runs rough, engine light comes on (flashes while running at first). I checked the battery and other obvious sensors, wires, vac lines etc...but nothing. After clearing error codes (by removing battery cable and cleaning) started fine, ran fine. After a short trip and turning off ignition, I found out my problem was back. I put a OBD tester on it and it shows no error codes, yet still runs rough.
Anyone have suggestions as where to start...electrical or fuel injec?
toyotabob is offline   Reply With Quote
Old 03-24-2007, 01:32 AM   #2 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Kind of sounds like a faulty coil pack. But on the 96 1mz if that happens then you loose two cylinders right?
V6LE_CAMRY is offline   Reply With Quote
Old 03-26-2007, 12:15 PM   #3 (permalink)
View bmxr4life87's Photo Gallery
no i beleieve its only the 1mz with the dual throttle bodies that have waste spark, my 95 1mz has individual coil packs, i think they started on 96 avalons and 97 camrys but i could be wrong??
bmxr4life87 is offline   Reply With Quote
what is your fav gen camry? 2dcamrystick Camry & Solara Lounge 42 09-17-2006 08:00 AM
Engine swap for gen 4 war0827 3rd & 4th Generation (1992–1996 & 1997–2001) 77 06-29-2004 09:59 PM
performance clutch gen 4 1mz I4 to V6 Swap 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-30-2004 10:49 PM
Wheel and Tire sizes different on Gen 3 v6 and Gen 3 5fse?? SoCaliCamry96 3rd & 4th Generation (1992–1996 & 1997–2001) 3 04-15-2004 01:12 PM
Gen # Trunk Question BigAirSkier1580 Camry & Solara Lounge 15 12-10-2003 04:54 PM
