Please help.changed fuel injectors now high idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2007, 06:54 PM   #1 (permalink)
View Unkle Kevin's Photo Gallery
00 Camry I changed two fuel injectors,new plenum gasket and plugs now I have a high idle problem and a flat spot when I try to accellerate.I hooked up and re-checked all vacuum lines.I spent half the day working on it and it runs worse then ever.ANY ideas?? It's a V-6 with 80.000 miles.
Unkle Kevin is offline   Reply With Quote
Old 03-24-2007, 06:56 PM   #2 (permalink)
5S-FU
View Sniperdude's Photo Gallery
Did you unplug your battery? You might need to reset the ECU.
Sniperdude is offline   Reply With Quote
Old 03-24-2007, 07:01 PM   #3 (permalink)
Yes I disconnected it for 2-3 minutes my engine light is on too.I was hoping that maybe the ECM may have to simply reset itself so I took it for a short drive but got spooked when it stumbled pretty bad on acceleration I thought it might die so I went home.
Old 03-24-2007, 10:46 PM   #4 (permalink)
5S-FU
Weird. Are the two you replaced on the fuel rail the same as the other two that are in there? Because if you have varying fuel spray ratios (cc's) it can get pretty ugly.
The other thing I might think of is double checking your distributor and spark wires. I had a problem with those the other day during some work....
Old 03-24-2007, 11:42 PM   #5 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
^ It has no distributor.
What does the CEL say?
5 Lug Corolla WHAT?
Old 03-24-2007, 11:50 PM   #6 (permalink)
5S-FU
Sorry, I thought it said Gen 3.
Old 03-24-2007, 11:57 PM   #7 (permalink)
94-96 V6 Camrys did not have a distributor either.
No prob though. Just a common mistake. I make my share on here.
5 Lug Corolla WHAT?
Old 03-25-2007, 12:42 AM   #8 (permalink)
5S-FU
Ah. I've never owned a V6. Wish I did though. Damn 4banger.
I used to have a Mercedes 600SEL V12. That thing was a beast.
Old 03-25-2007, 01:22 PM   #9 (permalink)
Thanks for the replies.There was a sensor not plugged in tight it runs awesome now as it should.Thanks again!
Help With idle rpm to high, rich exhaust and fuel consumption prolmem! Aus Paseo 92` Tercel, Paseo, Starlet, and Sera Forum 15 12-09-2007 10:25 PM
For Sale Brand New Camry Hybird for just $19000 cars01 Camry Hybrid 1 04-07-2007 06:00 PM
Fast Idle Adjust - too high chompy Pre-88 Toyota Pickup/Hilux 0 02-25-2007 07:19 PM
To all the performance gurus... Mid Life Crisis Camry & Solara Lounge 35 07-16-2006 03:34 PM
"Your Mileage May Differ" musubi 2nd Generation (2005+) 10 06-22-2006 02:56 PM
