pulley, sensors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2007, 11:10 AM   #1 (permalink)
View Natedawg's Photo Gallery
pulley, sensors
okay as you know i've been working for toyota as an entry level mechanic for about 2 days after leaving jiffy lube where the pay sucks and didn't teach me nothing. i want to become a toyota technician so i need alot of help guys..
1.customer states that the car will just start and shut off.. check engine light is crankshaft position sensor.. okay we replaced it.. it goes in block and into crankshaft.. now what does that sensor does.. please explain it good because i searched it up online and google and it confused me...
2. same thing what about cam shaft sensor...
3. okay now customer states that the car would start and stall out in the cold morning.. dude went ahead and said its the iacv valve.. how did he know that. how did he know it wasn't anything else.... is there a way u can test it.. how does the iacv valve work i know its located in throttle body.. theres like 3 coolant hoses going to it and like 3-4 vaccumm line how does that all work...
4. charcoal canister how does that exactly workagain i looked it up and i don't seem to really understand it...
5. okay on a camry we got 2 sensors one is AFR sensor and 02 sensor... how exactly does those 2 work and how are they different from each other...
6. none of the car have disturbutor beside the old school ones like old camry.. how does the new model work i see like 4 big squared things on the valve cover and has wires running to it.. pleas explain how it all work.. DIS ignition i believe...
7. also what is the idle pulley for.. like what does it actually does..
Natedawg is offline   Reply With Quote
Old 03-25-2007, 02:19 PM   #2 (permalink)
View JPaganel's Photo Gallery
As the name would imply, it tells the engine computer the position of the crankshaft, like is it at TDC or not. This is what the computer bases the timing on. Having a bad CPS is the same as having your distributor loose and rotating randomly.
What you said. Same thing. The sensor tells the computer where the camshaft is in it's revolution. Both of those sensors are basically magnetic switches that are opened and closed by the proximity of either some chunk of the shaft or a special piece of metal.
IACV stands for Idle Air Control Valve. So it's just IACV, or IAC valve.
What it does is control the opening of a small hole in the throttle body when the butterfly is closed. This way it acts like a small automatic throttle and controls the idle speed of the engine. It is reasonable to assume that a problem with idle would be caused by the Idle Control. You can test the valve coil for continuity and possibly for operation. I would hope this guy did test it rather than just replace it. A mechanic that would randomly replace crap without testing on my car would annoy me.
Charcoal absorbs stuff. In this case, gas fumes.
One senses the amout of air going into the intake, one senses oxygen content of exhaust. They work on different principles and screw into opposite ends of the engine
Magic. Yeah, that's it, it works on magic.
Realistically, there are books written on the subject, and pretty fat ones. Depends on the level of detail you want. If you want to get into the real nuts and bolts of it, you need to understand electronics and programming.
Basically, you've got a magic black box. Box takes in signals from sensors, and spits out signals to the ignition coils. (That's the square things onthe cover). It does this according to some program. So, this is just like your computer you used to post this that takes in signals from keyborad and mouse, does something to them according to a set of instructions, and spits out signals to a screen and a printer.
Well, if it's idle, it can't be doing much of anything, can it?
You probably mean "idler". If that's what you meant, you gotta be more specific. Serpentine belt idler? Timing belt idler?
Idler pulleys are generally pulleys that do not drive anything. They are there to route the belt.
Now, can you guess where I work?
JPaganel is offline   Reply With Quote
Old 03-25-2007, 08:59 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
^ yeah, what he said.
Old 03-25-2007, 10:17 PM   #4 (permalink)
toyota dealership well i'm knew and don't have that much experience.. and i can't learn off of the master tech or older guys because they don't have time to show and teach. their goal is in and out..
so if the iacv is bad than why would it make the car stall in the morning in the cold. and why does coolant line goes thru it. basicially your saying that when i have my foot on the throttle steady at a certain rpm it what holds the butterfly valve open automatically? i though thats what the throttle cable is for..
Old 03-25-2007, 11:00 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
good to see that you're learning, but out of curiosity- how'd you get the job if you don't even know how to deal with these problems? doesn't the position require some amount of tested knowledge, etc?
not ragging on you, but just curious
HaHa
Old 03-25-2007, 11:34 PM   #6 (permalink)
toyota dealership
Far from it. I'm a tech support analyst. My job is explaining complicated crap to people who don't understand.
That sucks. Where I work, it is specifically written into the job description of senior techs that they must train new guys. I would suggest maybe offering to buy lunch in exchange for some info. Take notes, if you can. Knowledgeable people get really pissed off if you ask them the same question two or three times.
Nope. You got it wrong.
The IACV does nothing to the butterfly. It is also inoperative when the butterfly is in any position except fully closed. It is a separate mini-throttle. If it fails to open, this would be the same as plugging the intake completely. No air getting in - engine no worky.
The coolant line does not go through the IACV. It goes through the throttle body, which is what the IACV is screwed into. It might be in the way and need to get disconnected to R/R the IACV. The purpose of the coolant line in the TB is to warm it up in cold weather so that the engine gets to the operating temperature faster. This is done for emissions, an engine running too cold produces dirtier exhaust.
Need advice for crankshaft pulley bolt removal BIG A Camry & Solara Lounge 13 08-13-2011 09:31 AM
ZPIRacing Lightweight Crank Pulley Install + Instructions white3ch0c0late Show & Share 31 02-12-2007 11:52 AM
Crankshaft pulley trouble... BIG BIG TROUBLE!! and little bit of reading... _VVTi_ Camry & Solara Lounge 12 06-18-2005 09:20 PM
A/F Sensors Replacement rohlal Camry & Solara Lounge 4 12-20-2004 11:42 AM
