1999 camry XLE V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2007, 09:42 PM   #1 (permalink)
hav
View hav's Photo Gallery
4th Generation 1999 camry XLE V6
I wanted to know any known issues with a 1999 XLE V6. Mine is auto. It has around 110 K on it and I just bought it from the dealer. I wanted to know if any routine maintenance had to be done or there are issues that need to be dealt with at this point of time. This one is manufactured in Japan.
Thanks
hav is offline   Reply With Quote
Old 03-25-2007, 10:22 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
oooh...JDM camry. if the timing belt has been changed then id just inspect seals and look for leaks. also u can perform this little free mod and cleaning post that could help.
http://www.toyotanation.com/forum/t45066.html
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-26-2007, 12:16 AM   #3 (permalink)
View krgs4's Photo Gallery
just check with the dealer...
have them run a service history off the vin.
in order or priority
1. Timing Belt and Water Pump-must be done at 100K interval-approx 750.00 service
2. Front Lower Ball Joints- only if you hear loud creaking over bumps-38.00 ea
3. Front Strut Mounts - only if you hear loud clunking over bumps-55.00 ea
4. Battery/alternator/starter-only if it is hard to start in the mornings.
5. The ONLY MAJOR issue is with ENGINE SLUDGE.
They (Toyota) MUST inspect your engine for this and will Replace with a new engine(if needed).
if you can get a Trans Tech Fluid Flush 79.00 local, 125.00 Toyota Dealership. well worth every penny. Have them use at least Automatic Trans Fluid of Dextron 3. or Toyota IV.
if you look into these 5 and do a flush..you will be smooth sailing.
krgs4 is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
2001 Camry XLE V6 Canadian version: JBL stereo? Tubbyc 3rd & 4th Generation (1992–1996 & 1997–2001) 1 04-26-2006 05:37 AM
