What is the difference in 5 speeds... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2007, 09:58 PM   #1 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
What is the difference in manual transmissions between the E153 and the 5 speed that came in the 92-93 camry's.....or are they the same? Inquiring minds want to know. Thanks for the help.
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 03-25-2007, 10:13 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
the 5 speed in the camry is the e153 i believe, the only differance is with gear ratios. the mr2 came with smaller gear ratios then the camry or solara because of the smaller powerband. im not sure if the tranny in the camry and solara were geared different from each other though.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 03-25-2007, 10:52 PM   #3 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I remember reading that the Solara was geared on a wider range than the one in the Mr2's and it was suggested that the Solara tranny was to be used for higher output cars. I think Tony the Tiger mentioned it.
And what bigbird said
RichieRichJP is offline   Reply With Quote
Old 03-25-2007, 11:17 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
http://www.mr2board.com/forums/mk-2-...?highlight=e52 That should cover most of that question.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-26-2007, 05:35 AM   #5 (permalink)
Knailgun's Avatar
excellent data
so I should think that an E53 (mine) should be identical (physically) to an E153 transmission (except for gearing)
I have a plan if it does
thanks for all the help
Old 03-26-2007, 09:55 AM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
uuh oh...man with a plan. let us know if it does.
R.I.P.
Car Domain:
Old 03-26-2007, 10:26 AM   #7 (permalink)
That was it!
Thanks
Old 03-26-2007, 02:09 PM   #8 (permalink)
Toysrme's Avatar
Cool
The bellhousing, etc is the same, the transmission casing is the same.
The gears are slightly different, the final drive is different, and the shift linkage is on the opposite side. Otherwise, yeah same thing.
Now with Turbo!
Old 03-26-2007, 02:30 PM   #9 (permalink)
Gameroom cash: $119055
View thaharlequin's Photo Gallery
Christ those are high strung, the automatic does better highway with the torque converter locked at 3.73/.734. Does anyone know if lower 5th gears are offered by anyone? Hopefully in the .4-.5:1 range.
thaharlequin is offline   Reply With Quote
20s, any difference? tacojoe 2nd Generation (2005+) 45 03-21-2006 09:17 PM
Aux. Input Adapter - IP-Bus to RCA...difference in adapters. pioneer. 87_SR5 Audio, Video, and Security - Tech 3 11-14-2005 06:53 PM
Difference Between Injen Intakes TRDCamryCL Camry & Solara Lounge 25 10-23-2005 05:23 PM
Difference between K&N and TRD? 2k4CamThrilla General Discussion 12 10-19-2005 05:56 PM
Pickup trucks What's the difference 2500HD vs 1500 touringcamry General Discussion 24 10-08-2005 11:12 PM
