Difference between 99 and 00/01 headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2007, 10:16 PM   #1 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I'm fairly new to the Gen4's, which I hope to be getting very soon. The current headlights are a bit fogged up so I want to get new ones, but I was looking at the 00/01 models and they look much nicer, as well as having daytime running lights, correct?
So my question is, what kind of modifications need to be done to fit an 00/01 headlight into a 99 Camry?
geoff5093 is offline   Reply With Quote
Old 03-25-2007, 11:21 PM   #2 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
View CJ Otey's Photo Gallery
http://toyotanation.com/forum/showthread.php?t=146723
heres a link to everything you need, you should try to search next time this has be covered a lot.
Two Toned 97 camry w/gen 4.5 front end conversion and 20" wheels and 2 Alpine Type R 15's in a vented box pushed by kicker zx1000.1
CJ Otey is offline   Reply With Quote
Old 03-25-2007, 11:22 PM   #3 (permalink)
xet
View xet's Photo Gallery
There are two main ways to make 4.5 lights fit gen 4 camrys. One is replacing fenders, bumpers, etc with gen 4.5 ones. Other is a bit of cutting and bending to get them to fit while keeping your reg parts. There is a diy for the second one just search for it
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 03-25-2007, 11:30 PM   #4 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
you dont need to replace your fenders just the bumper
Old 03-25-2007, 11:32 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
00/01 does not come standard with DRL.
2007 Camry 2.4L 5M
Old 03-26-2007, 09:23 AM   #6 (permalink)
geoff5093's Avatar
Thanks guys, and i always forget about the search feature, lol.
And I wouldnt want to replace the fender or grill, so I may just get the 4.5's and see if I can retrofit them in somehow.
Old 03-26-2007, 10:04 AM   #7 (permalink)
geoff5093's Avatar
I tried looking online, but couldnt find any info. Does anyone know the bulb type for the factory fog lights for a 99 camry?
Old 03-26-2007, 02:33 PM   #8 (permalink)
H3 and they are bitch to change.
2007 Camry 2.4L 5M
Old 03-26-2007, 03:15 PM   #9 (permalink)
geoff5093's Avatar
Really? Do you have to change them from behind the light or do you remove the plastic lens and remove it from there?
Both fog lights work, but one is alot brighter then the other, and I'd rather buy some new ones that match and if possible, get ones that are a bit more whitish.
Old 03-26-2007, 06:56 PM   #10 (permalink)
You need to first remove the plastic bezel around them (it's not part of the bumper). Then you remove the light from the bumper to change the bulb.
Well, that was the only way that I could get to them.
2007 Camry 2.4L 5M
Old 03-26-2007, 11:24 PM   #11 (permalink)
View leasaunce's Photo Gallery
I've replaced my gen 4 headlights with gen 4.5 headlights, just minor adjustment.
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 03-27-2007, 03:01 AM   #12 (permalink)
View AmanO's Photo Gallery
Gen 4-4.5 never had "factory" fogs. THere are dealer installed fogs and they are not hard to change. But kind of hard to get at.
You reach back and grab the back of the housing and twist clockwise 10-15 degrees. THen pull back and the back will come off with teh bulbs cable attached. Pull off the cable and decompress the spring holding the bulb in (almost the same spring as gen 4 headlight bulbs. Pull the bulb out and you are bulbless.
It may seem like taking the housing off is easier but I disagree. Plus one of the screws is part of the adjustment.
I have seen H3 led bulbs on ebay and am curious how they are.
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
