Bleeding brakes with ABS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2007, 10:59 AM   #1 (permalink)
View Xkontour98's Photo Gallery
I was wondering if there iwas a different proceedure for bleeding a Camry wth ABS vs Non-ABS? On my Ford there is a different proceedure, but I was wondering if that held true for the Camry.
Xkontour98 is offline   Reply With Quote
Old 03-26-2007, 07:57 PM   #2 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
same procedure for abs and non.
start with the wheel farthest from the master brake cylinder and end up on the one closest to it.
don't mix types of brake fluid and you're fine.
nodrogkam is offline   Reply With Quote
Old 03-29-2007, 02:50 PM   #3 (permalink)
Thanks, that is what I thought. I bled them just as you say with the proper fluid and the pedal is very spongy. I bled each caliper quite extensively and made sure no air went in and that there were no air bubbles present when it was bleeding out. Any suggestions?
Old 03-29-2007, 03:07 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
low pads
HaHa
Old 03-29-2007, 03:30 PM   #5 (permalink)
nodrogkam's Avatar
low pads, possible air in the master brake cyclinder, or old and weak rubber brake hoses that expand when under pressure and heat.
Problem bleeding brakes on 95 Camry soonergn 3rd & 4th Generation (1992–1996 & 1997–2001) 32 01-19-2011 11:47 PM
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
engine/ABS light help.... trninhds Camry & Solara Lounge 11 06-17-2006 11:06 PM
help with bleeding brakes pberg Pre-88 Toyota Pickup/Hilux 10 11-08-2005 01:53 PM
ABS Brakes on a 95 Camry. TigerRaptorFX 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-21-2002 11:16 PM
