Help diagnose a problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2007, 11:51 PM   #1 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
4th Generation Help diagnose a problem
Ok, friend has a probelm with his 4th gen camry.
year: 2000
engine: 5s-fe
tranny: auto
problem: when accelerating from stop, it feels like a manual tranny with a bad clutch. basically, it feels like you're letting the clutch out but not really and have a bad tendency to gas making the car lurch and shake and overall, it feels as if the gear is not fully engaging until about 2500 rpm. no problems in other gears. for instance, coming to a stop but not a ful stop and accelerating, no problem is there. also, letting go off the brake from a full stop for a few seconds before accelerating and then pressing the gas, no problem.
the problem is only there in normal driving only from standstill in first gear only. help please, thanks.
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 03-27-2007, 01:01 AM   #2 (permalink)
View Novice_cardude's Photo Gallery
Check the transmission fluid. If the level is okay, i'd have to say the torque converter is suspect.
However my experience with automatic transmissions is nil. All i know is basic theory, so you'll want to wait for more experienced folks to reply.
Novice_cardude is offline   Reply With Quote
Old 03-27-2007, 01:16 AM   #3 (permalink)
View toyomoho's Photo Gallery
See if there are any trouble codes stored. Sounds like something to do with the Foward Clutch system and a shop needs to look at it.
Old 03-27-2007, 02:13 PM   #4 (permalink)
Still confused...
^^ there is no check engine light.
Old 03-27-2007, 02:30 PM   #5 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
is anything running hot? any signs of overheating?
and what color is the trans. fluid? [and @ what level?]
Old 03-28-2007, 06:08 PM   #6 (permalink)
Unco's Avatar
View Unco's Photo Gallery
have you checked the transmission fluid level? if it's low, top it up and check for leaks. other than that, sounds like your auto transmission is shot. maybe it's just a faulty solenoid, but a slipping transmission is not a good thing and it's probably easier to replace it altogether.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-28-2007, 07:13 PM   #7 (permalink)
Still confused...
tranny fluid was a sorta slightly brownish unleasant color. he got the car used and wee\ figure the previous owner didn't do anything to take care of the tranny. the fluid level, however, is fine. anyone got a ballpark price for labor + transmission if he does decide to just swap it all out altogether?
Rant from a Toyota Tech toyota_tech_01 Scion Forum 30 09-10-2008 06:02 PM
Toyota Avalon 2005 Multi-Information Display Problem? uaesolidsnake 3rd Generation (2005-2012) 7 12-26-2006 05:07 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
