Originally Posted by eyeball96
Probably the cable broke...you can buy replacements at NAPA or Ebay for about 20 bucks..I just recently install an S2000 antenna on the coupe, before that I had a antenna I purchased from antennaX.com.(sig) Worked fine, good reception cheap! I got tired of fixing the power OEM antenna!.......The S2000 antenna looks much better IMO! (thanks Damon)
My friends ant is on the rear of his car by the trunk. I was looking online and the pics I saw were of ones on the front of the vehicle?
Also how hard was the install of the new ant? Which side of the car does the cable run? When you hooked up your s2000 you still had to run new wire right? Not to sure about alot of things as I don't own a camry. Thanks for the help guys. rod
