V6 exhaust manifold gasket, help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2007, 07:00 PM   #1 (permalink)
View DriveATransAm's Photo Gallery
is it easier to get the rear exhaust manifold gasket off from the top or the bottom? because it is on studs im guessing that i need to unbolt more of the exhaust somewhere down the line so it comes off easier?
this project is a pita.
'99 Corvette FRC Nassau Blue-For Sale
'07 Honda Shadow Sabre-For Sale
'09 Tacoma DC TRD sport
'10 Harley Road King Classic
DriveATransAm is offline   Reply With Quote
Old 03-27-2007, 07:15 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
the y-pipe comes off from the bottom.
the manifold requires both because of the EGR port & top nuts.
if your actualy manifold gasket is leaking, i'd begin to bet the manifold has cracked. the manifold gasket is multi-layer steel. it has no excuse to leak if it's under the correct tension.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-27-2007, 07:21 PM   #3 (permalink)
well i think i have all the EGR stuff off because the intake manifold is not on the car right now just the tube sticking up.
as far as the exhaust manifold not leaking, someone said its happened to them before. its a 94 with 211K miles on it. you could faintly hear a leak somewhere only when you trompped on the gas hard, with the windows down. then one day it just went and sounded like a big exhaust leak. you can hear it mostly at idle....once cruising on the expressway its almost impossible to hear (till you give it some gas to pass) im also almost certain its coming from the engine bay because a)i can smell it in the cabin pretty bad at stop lights, b)i couldnt find the leak from the y pipe back and sounds like its coming from near the engine as well. did they use mls for the original ones? i have so many nuts and bolts all over the place now im not sure this car is ever going to run again
exhaust manifold gasket justincyoung Tercel, Paseo, Starlet, and Sera Forum 5 01-23-2006 08:08 PM
anyone w/a gen 3 V6 and performance exhaust ag6286 3rd & 4th Generation (1992–1996 & 1997–2001) 32 06-30-2005 02:37 PM
New here, How hard to do a head gasket in a V6? bobsealover Camry & Solara Lounge 6 02-20-2004 02:53 AM
