Originally Posted by 400exboy2
hey guys i was just wondering if you all have any ideas how to free rusted exhaust bolts? i have a 93 camry with 136,000 miles on it and stock exhaust on it and i have a bad oil pan leak and it says in my haynes manuel that i have to take off the front exhaust piece. well i attempted to do it today but i couldnt break the bolts loose at the manifold. i put PB blaster on there and let it soak in but i still couldnt get them off.also i couldnt get the bolts off from the cat. converter but im just going to get the saw-saw and cut the bolts and put new ones anyone have any ideas? also one more last question does anyone know if you can use that stuff called lucas its supposed to fix leaks on a oil leak? thanks guys
i replaced oil pan on 94 camry, but i didn't have to take off the exhaust pipe, i used a flex head ratchet extension that i bought from walmart, but i guess if your 93 has exhaust on it's way, you can try to use drill to drill off the nut, not the bolt side, rather, begin with the smallest dril bit first on Nut, then move on to next size, take about 5 minutes, you can probably drill the whole nut off.
