i finally got around to replacing my oil pump o-ring. low and behold! my oil leak has stopped. i took pictures along the way in case anyone was interested. it actually turned out to be very easy to do (once the timing belt is off).
take off the lower timing belt pulley pictured.
timing belt pulley removed.
i removed the oil pump pulley now because i wasnt sure how everything was connected, but the outer assembly can be removed with the pulley still attached. i used a strap wrench to hold the pulley and a socket wrench on the nut. then unscrew the 7 bolts holding the outer assembly to the main pump body. take note of the location of the two smaller bolts.
the outer assumble was stuck in place, so i took a mallet and tapped the edges until it broke loose. the outer assembly will come out with the pulley shaft. BE CAREFUL this shaft doesnt slide out and hit the floor or get dinged/scraped up! once you, pull the shaft out from the backside. use a screwdriver to removed the old shaft seal.
carefully scrape the old o-ring off the outer assemble and main pump body. use some brake cleaner to clean off the old oil. pay close attention to clean out this little oil drail hole near where the shaft seal was.
with the assembly now clean, install the new shaft seal. i used a larger socket and a hammer to seat the seal. DO NOT press the seal in all of the way until it cant go in any further. you will cover that drain hole you cleaned out in the previous step. install the seal in far enough that the outside edge is even with the front surface of the outer assembly.
clean up the area the new o-ring will go on the pump main body. back to the outer assembly, before you install the pulley shaft, use some clean oil and lube up the surfaces that will make contact between the outer assembly and pulley shaft. to hold the o-ring in place, i dabbed a couple of small strageticly placed dots of RTV to hold the o-ring in place. then bolt the outer assembly back to the main body. turn the shaft as you install the outer assembly to slip the pump gear back together.
install the oil pump pulley, timing belt pulley and re-install the timing belt.
so... any questions?
