Ignition Timing Question - 3VZ-FE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2007, 12:43 AM   #1 (permalink)
View MarkE's Photo Gallery
Hey guys,
I just wanna make sure I set the timing properly. I set the notch on the crankshaft pulley to match the 0 on the guide (right above the pulley). The guide seems to go from -5 all the way to 15.
I jumped the TE1 to E1 and made sure the engine was warm. I also used the ignition wire on the front-right (the cylinder closest to the battery). The RPMs where hovering around 700-800.
BTW - I set the ignition timing to 10 on the guide but it ran pretty bad and had bad ping under light load.
Car Details:
1992 ES300
3VZ-FE / 5-speed manual
Thanks,
MarkE
MarkE is offline   Reply With Quote
Old 03-29-2007, 07:59 AM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Nope, gotta use the #1 spark plug, unless you want to do some math & make a gigantic gauge for the pulley.
Passanger most, firewall side is #1. It should read 10*btdc when you jump it. When you get it set to 10*btdc, you can run it up to 15*btdc for acouple extra horsepower & some throttle responce.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 03-29-2007, 07:22 PM   #3 (permalink)
Hey there Toys
Dammit...I can't find the dang notch when the clip is on that cylinder. You know what direction I should turn the distributor (facing the passenger side)? Clockwise?
Thanks,
MarkE
Old 03-29-2007, 07:24 PM   #4 (permalink)
Toysrme's Avatar
Cool
the dizzy has a notch on it, line it up with the notch on the valve cover. if the valvetrain is in alignment, that should be quite close to 10*btdc
Now with Turbo!
Old 04-15-2007, 04:53 PM   #5 (permalink)
Cool Problem Solved
Just for search purposes, I have solved the problem.
It turns out that the Harmonic Balancer was bad (the rubber thing in the middle was coming apart) and the timing notch moved over 200* from spec even though the timing was correct.
As a side note, I went to Toyota to get a quote and the part would've cost me $400 so I went to Autozone to get the part for 1/4 the price. My car is now set to ~13* BTDC.
Thanks for the replies Toys.
-MarkE
Old 04-15-2007, 07:36 PM   #6 (permalink)
Toysrme's Avatar
Cool
yw
Now set it to 15* lol
Now with Turbo!
Old 06-17-2007, 10:37 PM   #7 (permalink)
View deanp96pgt's Photo Gallery
so, just to make sure as I am having trouble setting the timing as per Haynes manual because of its inaccuracies but with terminal E1 and TE1 jumped, you should set the timing to 10* BTDC
my girlfriend doesnt desire more HP so I dont need to set it at 15* BTDC
deanp96pgt is offline   Reply With Quote
Crankshaft timing gear question hank2u Camry & Solara Lounge 4 08-21-2006 12:43 AM
94 Toyota Pickup 22re timing question MAXIMUS1968 89-95 Toyota Pickup/Hilux 17 08-12-2006 10:28 PM
Timing Question projectcelica07 Celica Forum 4 03-11-2006 04:46 AM
got a question about our timing 91turbo2 MR2 Forum 0 03-11-2004 12:44 AM
