Have to slam the doors to make them shut tight - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2007, 10:49 AM   #1 (permalink)
View zirconx's Photo Gallery
On my 97, both the driver and passenger doors take a good slam to make them shut. At best this is an annoyance, at worst it ends up leaving my dome and/or courtesy lights on, giving me a dead battery the next day.
Do you have to slam your doors to get them to latch all the way? Mine bounces a bit and then latches at half way. I can't for the life if me figure out what its hitting. Once its latched half way, I can push on the door and it moves in and out, but I can't push it hard enough to latch it all the way, you have to slam it to get it to do that.
The door sagged quite a bit when I got it, so I figured thats why it shut hard. But now I've fixed that, and it lines up perfectly. But its still hard to shut.
zirconx is offline   Reply With Quote
Old 03-29-2007, 11:03 AM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
My drivers side has to be slammed to close all the way, I sprayed alot of WD-40 on the latch mechanism, and now it doesnt have to be slammed shut.
geoff5093 is offline   Reply With Quote
Old 03-29-2007, 11:06 AM   #3 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
does it feel like its coming from the hinges/latches, or does it feel like the door isnt lining up correctly?
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 03-29-2007, 11:13 AM   #4 (permalink)
I did lube up the latch when I first got it, because it creaked. Maybe I'll double check and make sure its got plenty on there. The door 'slides' or 'coasts' toward the door pretty well though. I think there's a problem at the door, unless they are all just like this.
Old 03-29-2007, 11:17 AM   #5 (permalink)
It does not feel like its coming from the hinges. It feels like the door is not lining up properly with the frame or the latch. But it looks perfect from the inside and out.
It feels like the latch on the car is too far inward, and the door has to compress the weatherstripping too far to be able to shut correctly. But the door looks perfect when closed. Is that U shaped latch on the frame adjustable? I would need to adjust it outward a little, that may fix the problem.
Old 03-29-2007, 12:02 PM   #6 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
i got the same problem with my right hand side front and back doors...its been like this for about a year now havent sprayied anything onit
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 03-29-2007, 12:56 PM   #7 (permalink)
View keithy's Photo Gallery
I saw it in the service manual that, there is actually a way to adjust the latch mechanism. Look through the manual and maybe that may solve this problem.
keithy is offline   Reply With Quote
Old 03-29-2007, 02:39 PM   #8 (permalink)
View tarbasd's Photo Gallery
3rd Generation
Manual sasy you have to adjust the "loop" (or how it is called - the thing on the car frame, not on the door). However, it is a screw that you have to loose and I could not. Mine shuts a bit hard, but it's not too bad.
tarbasd is offline   Reply With Quote
Old 03-29-2007, 02:55 PM   #9 (permalink)
It takes a special bit, do you happen to know which one? I believe its a Torx bit. I have up to a T30 and its a little too small.
Old 03-29-2007, 08:58 PM   #10 (permalink)
I bought the bit, its a T40 Torx bit in case anyone ever needs to know. But its not adjustable. I took the two screws completely out, and there is no adjustment there. Just two boltholes.
After really studying it tonight, I think its the weatherstripping at the front of the door. The door may be bent so that it crimps it too tight, I don't know. I tried my best to bent it out but I could make no difference. I guess I'll just shut the door hard.
Old 03-29-2007, 09:15 PM   #11 (permalink)
Unco's Avatar
View Unco's Photo Gallery
can you take some pics of the part that you tried to adjust using the T40 Torx bit? on a Gen3 it's a standard Phillips head No3. i'm just surprised that they've gone to torx bits on the gen4 and i guess i'm just trying to see if you've pulled apart the right part. it is usually a common serviceable (adjustable) part.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 03-29-2007, 09:40 PM   #12 (permalink)
Sure. Here's a pic:
http://img168.imageshack.us/my.php?image=latchvv2.jpg
Old 03-29-2007, 10:35 PM   #13 (permalink)
alotawatts's Avatar
View alotawatts's Photo Gallery
Same on my 2000...but if any window in down ...like a pressure relief...no problem.
It's a Toyota feature !
04 Highlander 01 4Runner 00 Camry 90 Chev S10
alotawatts is offline   Reply With Quote
Old 03-29-2007, 10:39 PM   #14 (permalink)
Hmm maybe thats why the put a vent in the trunk in some models? Its a one way vent to let pressure out of the car.
Old 03-29-2007, 10:44 PM   #15 (permalink)
3rd Generation
It's strange that they changed the standard Philips from Gen 3 to Torx... so maybe it is only adjustable on a Gen 3. I will never know, because when I tried to loose the screws, my screwdriver started to bend, so I gave up.
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
DIY Cold-Air Intake bondobondo Hardcore Tech and Competition 40 11-24-2004 01:41 PM
Making other lights (or underglow) blink when lockin/openin doors with the remote aleks77 Camry & Solara Lounge 9 09-12-2004 03:41 AM
bored as hell at school... Razo-E Off Topic 43 07-29-2004 02:21 PM
