I need help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2007, 11:56 AM   #1 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
4th Generation I need help!
I've been noticing this for a moment now, but when I'm on a straught road I let go of the steering wheel and it begins to move to the left, no matter what speed. Also when i have the steering wheel straight and let the car move on its own, the steering tilts to the left a couple of degrees. What can be wrong?
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 03-29-2007, 12:55 PM   #2 (permalink)
View keithy's Photo Gallery
could be:
1. alignment issue
2. tire pressure
keithy is offline   Reply With Quote
Old 03-29-2007, 01:21 PM   #3 (permalink)
4th gen 2000 camry ce
View HOOKEDonLP's Photo Gallery
^^wat keithy said
tat would be my guess..... alignment if ur tires are fine
K&N air filter
non brand name strut bar
i always get wen ppl find out i drive a stick shift. i tell them that they a drive a stick shift too. then they reply, but urs a camry. every so often now a days. i get the surprise look of a camry being manual. hehehehehe.
HOOKEDonLP is offline   Reply With Quote
Old 03-30-2007, 02:20 AM   #4 (permalink)
Creeps228's Avatar
i done all of those, had my wheels aligned in october and im constantly putting air into the tires wat else can it be?
MR2: 7A-GE
Old 03-30-2007, 10:10 AM   #5 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Could be uneven wear? If you can prove to the mechanics that the alignment wasn't done properly, they should give you a new alignment for free.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 03-30-2007, 12:59 PM   #6 (permalink)
View Bluecam6's Photo Gallery
1 Try to swap the front tires and see if it pulls to the right. If it pulls the the right or go straight that the means the tire is no good. (belts in the tire have moved)
2 Try to move the front tires to the back and see if it gos straight.
3 If it is not the tires then it has to the the alignment.
4 is the front suspention part all good? Make sure the ball joints and tie rods struts and spings are all good..................
Bluecam6 is offline   Reply With Quote
Old 03-30-2007, 01:12 PM   #7 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
you coulld have knocked the alignment out since october. heck, a couple good shots from a pothole in the street can do wonders to an alignment job.
Old 03-30-2007, 02:00 PM   #8 (permalink)
Creeps228's Avatar
I manage to hit alot of those around here in new york, i'll go get the tires re-aligned and cheack tire pressue once more hopefully it work out
MR2: 7A-GE
Old 03-30-2007, 02:15 PM   #9 (permalink)
View devild599's Photo Gallery
it cud be that u have a bubble (lump) in one of ur tires. u get those lumps when u put too much air in ur tires... check ur tires, try changing them.
devild599 is offline   Reply With Quote
Old 03-30-2007, 03:08 PM   #10 (permalink)
Creeps228's Avatar
the tires are fine, I got them changed in december, little tire loss im thinking it could be the alignment of the tires
MR2: 7A-GE
