window motor, switch, regulator??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2007, 12:05 PM   #1 (permalink)
View mr magoo's Photo Gallery
Mt drivers window intermittantly stays down. I thought that it was the switch which I replaced, but the problem persists. When the window won't come back up, I slam the door a coupple of times and it usually comes backup. Regulator or cleaning of terminals?? Any suggestion or experience is appreciated.
thanks a million
mr magoo is offline   Reply With Quote
Old 03-29-2007, 12:52 PM   #2 (permalink)
View toyomoho's Photo Gallery
When the window fails to move is the motor working? If not check to make sure power from the switch is getting to the motor. Sounds like a loose wire.
Old 03-29-2007, 05:17 PM   #3 (permalink)
thanks for answering
When the window intermittantly won't go up, there is no motor sound. that's why I replaced the switch. I will check all connections the next time I am in there. Thanks for answering.
Is window regulator sold with motor? 66conv6 1st & 2nd Generation (1983–1986 & 1987-1991) 8 03-03-2007 08:21 PM
power window regulator removal sedona Camry & Solara Lounge 4 02-20-2006 08:32 PM
Help with lowering window when regulator out olddirtybaird Camry & Solara Lounge 10 01-13-2006 06:27 PM
Camry RH Window regulator & motor needed total1 Camry & Solara Lounge 9 05-24-2005 06:04 PM
2 door Camry Window Regulator Rico_S Camry & Solara Lounge 7 10-18-2004 02:45 PM
