98 camry clock and pwr mirrors don't work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2007, 01:51 PM   #1 (permalink)
slugmmco
View slugmmco's Photo Gallery
4th Generation 98 camry clock and pwr mirrors don't work
98 camry digital clock and power mirrors won't work. The power mirrors quit working first and then the digital clock. Fuses inside are good.
slugmmco is offline   Reply With Quote
Old 04-04-2007, 01:54 PM   #2 (permalink)
View steve97's Photo Gallery
It is the classic symptoms for a blown fuse. did you change the fuse, or just inspect it and put the same one back in?
steve97 is offline   Reply With Quote
Old 04-06-2007, 01:28 PM   #3 (permalink)
View toyomoho's Photo Gallery
The mirror and clock have the ECU-ACC fuse in common. The clock also uses the Gauge 1, Dome, Panel and IGN fuses.
Old 04-06-2007, 09:46 PM   #4 (permalink)
it's been a good ride
iTrader Score: 14 reviews
View camry_ricer's Photo Gallery
replace the fuse and you should be fine. it should be the 7.5v one.
my clock and my dome light had died on me, i replaced the fuse and everything works now, although im not sure if it will fix the mirror problem.
camry_ricer is offline   Reply With Quote
Old 04-21-2007, 07:34 PM   #5 (permalink)
slugmmco
Where are the dome, ECU-ACC, and IGN fuses located? All the fuses in the fuse panel left of the stering wheel have been replaced - still have the problem.
Old 04-21-2007, 07:53 PM   #6 (permalink)
View Red Camry's Photo Gallery
manual
CAMRYcoupe
Red Camry is offline   Reply With Quote
Old 04-21-2007, 10:28 PM   #7 (permalink)
ACC fuse should be in the driver’s side fuse box that you are talking about. IGN fuse is located in the engine compartment fuse box left side. For more detail and a schematic find the correct model car and download wiring info from the link below.
http://oregonstate.edu/~tongt/camry
