2000 Camry Knock Sensor Malfunction - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2007, 06:03 PM   #1 (permalink)
View twl527's Photo Gallery
The check engine light in my 2000 Toyota Camry 4 cylinder has recently started to come on intermittently. I took it to Autozone and they said that the problem was code P0325 (Knock sensor Malfunction). I read that I should check the continuity between the lead and the body of the sensor to see if the sensor is faulty. Can someone tell me where on the engine to find the sensor?
Thanks,
Ted
twl527 is offline   Reply With Quote
2000 Camry Maintenance Diy Tips cnn 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-27-2011 12:04 AM
Knock Sensor wire on 96 Camry Dusty Drake 3rd & 4th Generation (1992–1996 & 1997–2001) 5 10-30-2006 09:40 PM
need advice: what should my next mod be? 2000 camry cman2000 3rd & 4th Generation (1992–1996 & 1997–2001) 17 11-16-2004 11:05 PM
Camry 2000 Hood Latch mkrishna95050 3rd & 4th Generation (1992–1996 & 1997–2001) 0 10-11-2004 08:05 PM
Would Infiniti G35 rims fit on 2000 camry XLE? aleks77 General Discussion 29 11-09-2003 01:47 AM
