Rear Main Seal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2007, 10:44 AM   #1 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
3rd Generation Rear Main Seal
After spending $400 to do my Valve Cover Gasket, Dist O-Ring seal, Oil Pan gasket, turns out that my Rear Main Seal was leaking oil also. My friend mechanic says, it is a $700 job, transmission has to come down....
I just did the above (not main seal) 2 years ago, but used aftermarket seals...this time we used Toyota OEM.
So, tough sheet, I will have to bear the oil leak from the Rear Main Seal.
Has anyone done it and how much did it cost you? What are the pitfalls, or stuff to watch out for to get it done?
mandyfig is offline   Reply With Quote
Old 04-01-2007, 10:46 AM   #2 (permalink)
mandyfig's Avatar
Sorry delete multiple posting...
Old 04-01-2007, 03:31 PM   #3 (permalink)
5S-FU
View Sniperdude's Photo Gallery
When your rear main seal gets real bad, you'll be losing up to a quart every 5 - 10 minutes while the motor is on. Trust me, I learned that the hard way.
850 for the whole job, including the seals and gaskets you already mentioned.
Sniperdude is offline   Reply With Quote
Old 04-02-2007, 01:10 PM   #4 (permalink)
2004 HL Ltd. 4WD V6
View rayprog's Photo Gallery
About same quote ($870 CND) was given to me by dillership. It is not leaking badly yet, so I'm using some "stop leak" for now.
rayprog is offline   Reply With Quote
Old 07-23-2007, 04:49 PM   #5 (permalink)
mandyfig's Avatar
rayprog STOP LEAK
What are you using? Where do you get them? Do they help?
04 SC430 05 RX330
96 Camry LE T-boned Oct. 09 RIP
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
Blew my rear main seal 99Camry99 3rd & 4th Generation (1992–1996 & 1997–2001) 4 12-14-2006 05:19 PM
Leaking rear main seal 5SFE question mj8 3rd & 4th Generation (1992–1996 & 1997–2001) 12 11-02-2006 02:51 PM
