Need a set of brake pipes. Cost? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2007, 10:08 AM   #1 (permalink)
Found this name
View ejaymclane's Photo Gallery
3rd Generation Need a set of brake pipes. Cost?
I took my car for its MOT (annual safety check) and it failed. It needs some bulb adjustments (nothing really) and both rear brake pipes replacing as they have corroded.
The mechanic said he couldnt give a price to do the work as he couldnt get to the pipes to have a good look.
Does anyone know what kind of money it should cost to replace the pipes inc labour on a 1995 Camry?
Thanks
ejaymclane is offline   Reply With Quote
Old 04-05-2007, 10:22 AM   #2 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
You mean the brake lines? The ones that lead to the calipers or the ones under the car? Both are cheap and shouldn't cost too much to fix. The lines leading tot he caliper are fairly easy to change and you can do it yourself.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 04-06-2007, 12:40 PM   #3 (permalink)
View marc780's Photo Gallery
The brake HOSES are made of rubber-like stuff and are the flexible hoses to the brakes. They're a snap to replace, i could change two of them in about an hour including bleeding.
The brake lines are the STEEL hard lines running underneath the car. You can buy these at the auto parts all made up with fittings. But if there are any bends in the lines, or they do not have your exact length avaialable, you will need special tools like tubing benders and flare nut tools. .
Brake Job Totural Pimpinda93camry 3rd & 4th Generation (1992–1996 & 1997–2001) 10 10-11-2010 12:52 PM
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
STRANGE Camry Brake Problem, Plz help!!! Tarzan Camry & Solara Lounge 15 03-18-2006 02:28 AM
Tools what do you have? bowlofturtle Off Topic 27 02-14-2005 11:16 PM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
