Originally Posted by Toysrme
An air-assisted fuel injection system employs an alternate path so that the airflow can take another route down to the intake manifold, where it re-mixes with the normal flow from an area surrounding the injector pintel. This promites higher atomization, and economy. Especially at low/part throttle.
Thanks for the reply. I still don't quit understand the purpose of this system. Based on this explaination, I have the following questions:
"alternate path" alternate path to and from where? There olny seems to be an outlet at the TB. The FI tips are sealed with an O-ring, so air shouldn't be drawn through them.
"re-mixes" how is the air being mixed the first time?
"higher atomization, and economy" If this is true, why would Toyota stop using this system?
And to clarify, I do understand how the IAC works and what it does, I just don't understand how the "air-assisted FI" works. Maybe this is the correct explaination and it just needs to be "dumbed down" a few levels so I can understand it.
Thanks, Jim
